QUOTE(Jeffs9146 @ Sep 21 2011, 05:59 PM)
It would help to see detailed photos!
Does the original 6 still have the 2.0L included out of the car? Is the trans an original 6 trans? How is the Hell Hole rust and the over all condition of the car? $10K - $40K or more!
Conversions can be all over the map but a well sorted one can go for good money depending on what kind of details and restorations were done in the process! $8K - $30K!
So photos and details!
I'll have photos for everyone to see tomorrow evening. Don't hold me to these details until I can double check tomorrow since it's all from memory right now but here's what I can say of both (I'll have more info on the clone since I built it). And I apologize now if my descriptions are a bit naive or off, but I'm still new to the Porsche world.
Some Back Story on the OwnerChuck McCart was an E.R. Doctor with more people biding for his time than his heart could say no to. Always quick to help anyone with a need he found himself working looong hours everyday at the hospital as well as serving as medical director and adviser for multiple organizations. He was a man who was incredibly meticulous about everything that he did. I think largely in part because of his background as a helicopter pilot and Doctor. He flew through Vietnam as a young man and then returned to the states to run his own helicopter based fire fighting business, and then at 37 went to medical school to become a doctor. He was a lover of anything that went fast. Sports cars (including his 914s, Boxster, and AC Shelby Cobra), airplanes, and helicopters were his passions.
Real 1970 914-6- Red exterior (and I believe that years ago it was yellow)
- Black interior
- GT Flares
- Currently has a 3.0L with 40mm Webers
- Original 2.0L is included as well. It seized up when installed in the '71 clone as the diagram that came with our fender mounted oil tank showed the lines plumbed backwards. Consequently when we started it up, it ran it for about 30 seconds, then stopped and would not turn over at all. Extent of internal damage is unknown. Could be minor, could be major. We opted to pull the motor and go a different route rather than tear into and rebuild this one. But we do still have it and it will be included with the car if wanted.
- Momo steering wheel
- Transmission has been greatly improved from everything that Chuck had told (he was extremely proud of how it was built) me but I don't remember the extent of work done to it. Hopefully the pictures tomorrow will be clear as day for those of you who know more about these than I do.
- 4-Point belts
- Front trunk mounted oil cooler with oil lines plumbed in the driver side rocker panel
- 2-piece BBS Wheels (the original Fuchs are on the clone)
- Custom built and tuned stainless steel exhaust
What's wrongI haven't seen this car run in a couple years namely because of Chuck's extremely busy schedule. Before parking it though he frequented any track days he could get to as well as running at Laguna Seca Raceway as I'm sure many of you have as well. There is a significant oil leak of some sort as there was a substantial amount of oil under it at one point (possibly a cracked oil line if I had to guess)
1971 914-6 CLONE- Red exterior (the car was blue at one point as evidenced by the blue paint on the underside of the rear trunk)
- Black Interior
- Mild Flares
- 2.7L out of a 911 with 40mm Weber carbs
- Firewall welded motor mount with sportmount bushings
- Oil tank in 914-6 fashion is mounted in the driver side fender well
- Sideshift transmission with new shift rod bushings at the firewall and end of shift rod where it connects to the transmission
- High-performance axles
- 5 lug hubs
- Fuchs wheels from the 914-6
- Upgraded coilovers (I'll check what springs and shocks they are)
- Second oil cooler is mounted in the rear passenger fender well with a 6” thermostatically controlled electric fan
- Upgraded electric fuel pump
- Engine bay is painted satin black and engine is a black and red scheme. Most everything that's red on the engine has been powdercoated, not painted
- MSD Ignition
- Brand new Bursch tuned exhaust
- Hell Hole has been cut out and replaced with new sheetmetal welded in
- New heater flapper boxes on the exhaust
- Fuse box has been replaced with modern fuse block
What's wrong - Two things. Before being diagnosed Chuck noticed that one of the headlights would sometimes stick when opening so he took both of them apart and didn't get a chance to reinstall them. And while putting some miles on it after finishing the build we noticed that the handling just wasn't perfect. When we took it in for an alignment they said that it had a bent strut. Again, with plans of replacing it, Chuck removed the front driver side strut and hadn't had a chance to replace it before things went south.
Again, I'll take loads of pictures tomorrow and get those up. I agree that it would be in our best interest to get better educated opinions from people more engrossed in this line of cars. And no, Gail isn't pressed to sell these. She just doesn't have a need for them or any strong sentimental attachment so she asked if I would be willing to see if I might be able to help her sell them. They were Chuck's babies. Thanks again for all the input and advice everyone.
