Bill Meyer
Sep 29 2011, 03:15 PM
I'm bolting down this pressure plate here and something doesn't seem right. As you can see the bolt face goes into the recess on the flywheel. It doesn't hit, but your socket starts slipping since it starts hitting the flywheel. I suppose I can tighten it down carefully with a wrench, but I don't remember this issue when taking it off the old motor.
Confused??...
underthetire
Sep 29 2011, 03:22 PM
Yep, been there. Get your flywheel machined recently?
proto31
Sep 29 2011, 03:25 PM
Use allen bolts, make sure that they are 10.9 hardened...
Bill Meyer
Sep 29 2011, 03:44 PM
As a matter of fact it was machined, that explains it, duh... Good idea on the allen bolts.
Thanks guys!!
QUOTE(proto31 @ Sep 29 2011, 04:25 PM)
Mike D.
Sep 29 2011, 04:32 PM
I have a hardened 13mm for impact wrench that "machined" down around the edge just for this purpose.
76-914
Sep 29 2011, 04:38 PM
QUOTE(Mike D. @ Sep 29 2011, 03:32 PM)
What he said. Except my machining was hillbilly; done on a grinder:beer2:
Mike D.
Sep 29 2011, 04:43 PM
QUOTE(76-914 @ Sep 29 2011, 03:38 PM)
Mine too, thats why "machined" is in quotes.
Cap'n Krusty
Sep 29 2011, 05:12 PM
If it's that deep, I certainly wouldn't use it. You can't shim the release bearing ball out far enough to make the arm move properly, not to mention clutch disc hub to flywheel bolt clearance.
The Cap'n
