Skiking:
To replaced the intake hoses you need to remove your injectors (mark injector wires so you won't hook up wrong when you reassemble), remove the manifold nuts (see grey nuts in picture below) and the remove the intake manifold, my old manifold hoses were like a rock when I removed them! To replace simply side on. While I had the intake manifold off I replaced the gasket too. Here is gasket link on Pelican:
http://www.pelicanparts.com/cgi-bin/smart/...75%29%2C%20eachSince you have the injectors off, consider replacing the fuel injector seals. They are real cheap and easy to replace:
http://www.pelicanparts.com/cgi-bin/smart/...76%29%2C%20EachI also sanded and repainted the manifolds with Engine Enamel paint! Really dressed up the engine!
See picture below.
Hope this helps, Terry
Note: My manifold hoses are silicone which I got from a fellow 914Worlder.
QUOTE(skiking @ Jul 14 2012, 06:50 PM)
QUOTE(skiking @ Oct 17 2011, 03:54 PM)
QUOTE(PDXMike @ Oct 14 2011, 07:27 AM)
I bought the intake manifold hoses cut to length from Pelican. $4 each, $16 total. They went on very easily.
The rest vacuum (and fuel) hose layout is here:
http://www.pelicanparts.com/914/technical_...4_18fi_diag.htmI bought a vacuum hose kit from AA but was disappointed as I felt that it was incomplete. You might be better off just buying hose separately. The link above includes a table showing everything you need.
You're going to have trouble finding 18 and 22mm hose. That's why I bought the kit from AA, but then it didn't come with the 22mm hose anyway and I had to reuse my old 22mm one. I just put hose clamps on the ends and it seems to be OK.
Thanks, Mike! You mention you were unhappy with the AA hose kit - I'm curious what that was lacking besides the breather?
Mike,
i don't know if you'll get this email, but I thought I'd try. I've replaced all vacuum hoses with the (4) intake manifold hoses remaining to be installed. You mentioned they went on easily - would you mind letting me know how you removed the old and installed the new?
Thanks, Robbie
