Full Version: ? whats needed to 1.7 block and heads to install 94mm P&Cs
jimkelly
?? whats needed to 1.7 block and heads to install 94mm P&Cs ??
i ask because i have a set of 94mm P&Cs for sale i a potential buyer has asked me this very question.
http://www.914world.com/bbs2/index.php?showtopic=148938
between you and me - i am pretty sure the block and the heads will need machining.
will bigger P&Cs in a otherwise stock 1.7 bring more HP?
thanks
jim
** of course being in sales, i said, "hell yeah" " they will fit right in, no problem" but now i am feeling guilty about that. damn, i hate having a conscience : )
jaxdream
From what I've read that others more knowledgeable than me , say block no need , heads definately .Check out Jakes web , might give some specs .
As far as sales go , well .........
Jack
914rat
The spigots on the case are the same on all cases.The heads on a 1.7 will need to be opened up to accept the larger cylinders.
How much for the P&C's ? Anything you need in trade?
jimkelly
thanks guys.
and i am pretty sure 1.8 heads can be used without modification?
jim
VaccaRabite
Block will be fine but the cylinder registers need to be checked to see if they are collapsing.
Heads will need to be cut to accept bigger cylinders.
If you have 1.8 heads they should work fine.
Zach
bam914
The pin height on the 2.0L pistons is less then the 1.7-1.8. If he plans to use the 66mm stroke crank he will have a huge deck height.
jimkelly
so it sounds like with these P&Cs.
1- any block can be used.
2- 1.8 and 2.0 heads can be used unmachined.
3- 2.0 crank and rods should be used.
Jake Raby
Detailed article on this subject can be found on my forums.
