QUOTE(bongo monkey @ Aug 6 2004, 07:11 PM)
I'm having the same problem as Jenny (except it was the PO who put the mirror on wrong... yeah, the PO
I tried a scraper with a razor blade. No success, that sucker is on there TIGHT. Can't even get it 1mm under the base.
I'm thinking heat. Lots of heat. Will that pop the mirror right off?
The guy at the glass shop told me I should of used heat
but not to much heat becouse it will melt the laminate between the glass.
I got my new window installed today.
$240.00 with the rubber trim around the window to replace the chrome.
Turned out good. I'm quite happy with it.
I will post a pic if anybody wants to see it.
