QUOTE(TimT @ Aug 12 2004, 01:51 PM)
Im kinda surprised this thread didnt really take off..
BTW my 2.2 put out about 180 hp before I changed the cam/twin plugged/ EFI'd it.. im looking for around 200 now...
it's really a niche publication, and subject.
very, very few people will ever ACTUALLY engage in a 911 rebuild project. look how few people here actually rebuild /4 engines. the few who do, do quite a few, and the ones who do it for the first time generate a lot of message traffic - but that's still not a lot of people.
i think most of the people who get into 6's "just hope' nothing big ever goes bad, or are resigned to having a shop do the work.
a 2,2S was rated at 180HP. i'm starting with an E, looking at a 0,040" bump to 2,2+ with 85mm 9,8:1 (S-spec) JE pistons. the S cams are a lot more radical and while the valves are the same size, the S ports were a bit bigger. and since i'm building a street, DE, AX car, i think i'll be happier with a broad, flat E-cam torque curve than a higher but peakier S curve. plus i donno how well an E MFI space cam would be matched to S cams, and i'm disinclined to have the pump overhauled just now.
if the car turns out to be a long-term keeper, i still have the opportunity to re-freshen it in a couple of years with Nickies (drooling but choking on $2600, a $400 exchange overbore is looking really attractive just now...), Cosworth 'CP' pistons, S cams and heads, and a MFI pump overhaul. for now, a bit of a performance bump and solid reliability is what i need...
i think with the displacement and compression bumps i should be a bit over the S-spec 180, although i doubt i'll see over 200 without a cam change.
