That is pretty cool!
Make sure you check all those fuel lines as they're notrious for leaking fuel lines causing engine/car fires.
Check the the brake lines/MC?calipers/system after sitting that long too!
And a cracked/leaking vacuum hose can make them idle bad,
... or maybe the cold start valve/5th injector is frozen/plugged?
