QUOTE(stugray @ Dec 9 2011, 02:47 PM)
1 - go get a GOOD set of dental picks. Craftsman will work.
2 - To put in the new clip, you set it over the hole, then using the dental pick, get under the last "loop" of the clip in back. You should be able to push that down into the hole, then keep working your way around until it is all in there and the last bit will click in.
3 - to remove, see the little "notch" in the end of the clip ring?
You would reach into the hole and grab that with the dental pick, and work it back out the reverse of how it went in.
Stu
I bought a set from Lowe's to get the rear calipers dismantled. Can't be done without a pick of some sort. Now I get to use it again.
