QUOTE(Porsche930dude @ Dec 18 2011, 08:38 PM)
Im new to the 914s and im going to be putting together my 1.7 after i tore it down to clean up flood damage and not running in 25 years. So far so good but im wondering if there is anything internally i should be checking or modifying before i reassemble it. Im not sure if it has been apart before or not
It's that ole saying, "while your in there". If you are taking it apart, you should add new parts, bearings at a minimum. But you should consider, the cam, lifters, etc... If you can find a Type 4 machine shop they can check lots of measurements. The heads most likely have cracks too. They can be welded. Maybe new seats, valves, etc... the list goes on and on. Do some research on here and you will find most of the specs and wear limits.
