Full Version: new to this
skatbox1
so i just got me a 75 914 and the person i got the car from doesnt have the keys...wondering is there a little trick or another key i may use....or do i just have to replace the whole switch... sorry just new to this world.... thanks in advance
cwpeden
I know that the key from my buddies 73 works in mine both doors and ignition.....only cause after 38 years its only a bumpy metal stick. And all bumpy metal sticks look the same. confused24.gif
bulitt
Welcome to the world of 914 and PO's that hand you a ring of keys of which none work! My ignition key is the only one that worked when I bought the car so I was spared the process of figuring that out.
I think I read there was about 40 keys total for these cars and some dealers have a drawer full they can try on your car. You can buy replacement switchs and keys- several on Ebay right now.
The 914 had separate keys for ignition, doors, trunk, glove box, sort of like a valet set up. Screw that, Once you can get a working ignition key you can easily re-key the other locks by following the procedure on the Pelican parts tech site. If you decide to tackle the door re-key buy the plastic replaceable mechanism part prior (one per door), good time to replace as you have the handle off.
Now you have one key that operates your 914!
SLITS
Talk to a locksmith and see if they can cut a key on site
or
Remove steering wheel and column switch assemblies exposing the screws that hold the lock cylinder in. Remove those exposing the tumbler switch.
Now you have to figure a slim tool to depress the column locking pawl. Tumbler switch won't come out unless it is depressed. Not easy, but it can be done
or
As above, but remove the entire steering column assembly. 4 alen head screws & one pinch bolt on shaft universal joint & take it to a locksmith
or
find a key that works
skatbox1
cool deal thanks guys... i think i might try the locksmith first then taking it apart.. i was just hoping like a vw key might fit cause i know my brothers ford galaxy key fit my friends ford escort.. again thanks guys
brant
QUOTE(bulitt @ Dec 30 2011, 05:20 AM) *
What?
your car must have had a previous owner replacing door handles or ignition switch...
originally they did not have 3+ keys
they had 1 key that fit everything
and a 2nd key that fit the doors/ignition, but wouldn't open the trunk-lock, glovebox-lock
brant
