First.....
Thanks for the welcome...I've been away from 914's for awhile but have owned 7...my 1st was a daily driver from 77'-88' Pro's & Con's to what you want to do....but it's your car & your checkbook!
I think that his/her input was based upon it ostensibly being a pristine very low mileage survivor in original paint (if it indeed has never been repainted), which are very few & far between nowadays, and command a price/value premium in the marketplace. At 36-37 years old, that's only an average of about 1700 miles/yr - or long period(s0 time just sitting undriven!
I wouldn't say it's pristine...but I do know from my other 914's that this one has original rivots in the rocker panels, and nearly every bolt/screw (except service items) look original. I get your point about if it has indeed not been repainted...I guess I will find out when I did a little deeper and get it ready for painting However, before you take the "low mile survivor" route too far, you first need to be able to document from the service records/etc. back to day one `75 (or Fall 74) when first sold, that the odometer hasn't turned-over nor been reset. Unfortunately with P-cars from that era, the 5 digit odometer "lies" because you generally cannot tell whether a car has gone 99,999 or less - or if it's been 100k, 200k, 300k or more (less than average 15k/yr - say at even 2/3's of 10k/yr would be 360-370k now on a 75).
I do have some records. I was able to contact the 2nd owner (who had it for 29 years) and I do have the name/address of the 1st owner as filled in on the maintenance book. I'm confident that the odo has not rolled, but not sure how long the speedo cable has been broke So first research your records that you got with the 914 if a new purchase, or that you've hopefully saved if you bought it new, and try to determine if it's really a 62k mile car, and also look at wear on things like gas pedal, carpets & seats, etc. to see if it LOOKS like it's really a low mileage car - &/or if it has had the interior redone, gas pedal changed for a new one, etc. - or has excessive wear.
the wear items all look good, it has a set of Michelin XZX's (early 90's era) on it that look brand new, still have the tits on the sidewalls I've looked at several other 73-74 914-2.0s over the past 1-2 years as a more cost effective alternative to restoring/repairing my 73 2L, and most were not truly at the stated mileage by condition alone, nor could they be documented. They're just few & far between & most owners go by what the last owner said when selling - whether mistakenly or intentionally wrong.
I was looking for a 914 to create a good restored car that I could do what I wanted with...when I found this one, I could not pass it up. probably not the right candidate to pull apart and redo...to your point about few and faw between...I couldn't pass this up Also get a Certificate of Authenticity (COA) from Porsche/PCNA to make sure that it's engine (and transaxle) numbers match what is in the 914 now - vs. what the Porsche "Kardex" build records on microfilm/digiat at PCNA say they are/were. A non-numbers matching car with a swapped engine or rebuilt 2.0 from a 1.8 OE will not be worth as much.
good advice, i was just going by the published #'s. I know they don't have vin #'s on engines to actually have matching #'s like American muslce cars do, here are the numbers on the engine GC000243, the VIN is 4752900696, and it was built 8/74 If it's only the dents, then you can get a paintless dent repair shop to repair it by massaging it out (or get the PDR tools & do it yourself), then if it has some chips & scratches you can get those airbrushed by a quality resto shop to match the existing paint.
Ther are 2 small dents in the drivers door near the bottom that are about an 1/8" deep about 2" apart, no broke paint, the other is on the other side, at the bottom of the front fender that is just a bad scrape about 2" on the fender and about 4" on the door...that broke the paint and is covered up by hand brushed on touch up paint. there is a chip on the hood that has black paint under it...leading me to think the hood was painted at some point. all the dent look like they happened from being stuck in the corner of the garage for years As for the back-dated bumpers - well you wouldn't do it on a low mile survivor by cutting into the body shell - because you don't want anything non-reversible to sell it for the premium here. Talk to Scarlet75/Andy on here, as he just did his 75 1.8 & I'm pretty sure he didn't cut anything on the body panels to do it. If it's not really a low mileage survivor & you repaint ti, then just do a good job on it & repaint it properly.
I was thinking you could back date w/o doing permenent damage...the fed bumpers were actually a modification by the factory anyway As for the EFI - folks usually change them out for a carb system because either they cannot get the EFI to work & don't have the money &/or mechanic with expertise nearby; or else for more power (but a 2056 big bore 2L can still get 110-125+/- HP with the D-jet EFI & "look stock"). Usually it's the "I can't get it to work" reason, but IMHO the EFI is a better set-up & you don't need to screw with sync-ing carbs, which was a major motivator for my buying my 73 914-2.0 in Dec `75! A pristine survivor is more valuable with the original engine & EFI, transaxle, etc. - with replacement & maintenance/rebuilds as necessary & appropriate.
I'm conserned about making the EFI work...I do have the original system in a box. I can appriciate not having to keep the dual carbs tuned. I'm not so much conserned about the HP, just want it to be strong enough. Not going to AutoX or track it...I have a car I do track events with that has about 5x HP the 75' 2L 914 has. I want to be able to do some PCA stuff, a few casual car shows (not interested in having a 1000 point stock original to compete with) Most CW (Concours Weenie) future buyers of your 75 - if a survivor, would want it to qualify for the PCA's & other concours event sponsors' rules that a preservation or survivor class car have all original parts on them, be unmodified (e.g.: no carbs on a 914), & that 80% of the paint is still original. Otherwise they go up against fully restored cars in another class in most cases.
that's probably the only way vendor A's value of $19.5K would happen...I don't want a car that I have to put in a wrapper, take it out for a show a couple times a year and then wrap it back up If you decide to take it back to EFI, then Brad Mayeur in Peoria IL - sorta across the Big Muddy from you - knows 914s well & can surely get it sorted out for you & probably can find the "missing" EFI parts as well.
Cool So if it all checks out as a truly well kept low mileage survivor, then you should probably weigh the options of modifying it, or looking for a less pristine & higher mileage non-survivor 914 to do your hi-performance mods on, and maybe keep it as your show car (then you'd be twin-teener owner!
); or sell it for better money now to fund the hot-rod-914 project & car you really want.
I do have a really rough 74' that has fabricated (non-914/6) steel fender flares on it...it has been sitting outside for years...it apparently was in a front end collision and had a 73' front grafted on...not sure that is ever going to see pavement again...the fender flares and slope nose does look good though Of course it's YOUR car & YOUR money - so you can certainly do what YOU want with it either way, but make it a well informed decision, since you could be leaving $1000s in value "on the table" by modifying a true & documented low mileage 914 survivor.
I do appreciate you taking the time to help guide me to a decision. I'm guessing that the "vendor's" enthusiasm about hearing of a low mileage original 914 got the better of him/her
- and said something like: "...you'd be crazy to...." - which unfortunately is a symptom of this classic car & 914 crazy disease we all have!
He actually said he was going to tell me what I should do and not what I wanted to hear...I was a little creative with my title wanting to get a lot on input and not skipped over with another "what would you do" thread The Originality & History Forum topics on here can give you guidance on the survivor aspects, while the Garage Forums have the mod stuff.
Thanks again for your guidenss...looking forward to being back in the 914 area again. FYI - this is one of my SoCal area buddy's 71 914/4 1.7L that he's owned since new with <61k miles, still wearing original paint that he had airbrushed in matching Bahia Red paint where it had a few usage chips & a stucco scrape he did on the garage wall - maybe 2-3% overall repainted/touched & perfectly blended, the carpets & upholstery are still all original. The Rosewood dash face, turned aluminum threshold plates, hood badge, & Western Wheels were put on by the original dealer for a buyer who backed out, before my buddy bought it new in `71. He has since replaced the rocker covers, put in new Coco mats, added the combo fuel/temp gauge from a 914-6 & a modern disc player into the glovebox with new speakers in the footwell boxes, rechromed F bumper with the Lic. plate mounting holes welded up - but not much else, and he saved the original stuff.
it does look schweeet and is very inspirational Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment This is to show you what a comparable age & mileage 914 survivor should look like to have the highest value (the dash, wheels, F bumber, etc. might be removed & changed back to OE by a hard core CW). Hope this helps in your quest for answers.
This does help tremendously...this is what I want my 914 to be a great, clean, rust free, gook looking car, with power enough to live up to a good 2L Good Luck on your Quest!
Tom
