Why do "performance" cams with greater lift/duration specify greater valve lash? Is it a performance gain, or durability, longevity gain?
I just recently received the cam specs for my engine from the PO. It shows valve clearance should be set at:
.013N
.015X
This just seems really loose! Is this for very high rpm?
The engine is a 75 2.0 with 44IDF's, Euro P/C's, Mallory dizzy & CD, and has Iskendarian cam, lifters, pushrods & springs.
I just recently had some headwork done and replaced the valves. Should I use the above specs instead of .006/.008?
