QUOTE(rohar @ Jan 20 2012, 01:02 PM)
QUOTE(Racer Chris @ Jan 20 2012, 09:27 AM)
QUOTE(BIGKAT_83 @ Jan 20 2012, 07:56 AM)
Why would anyone go to all that trouble and then use those POS Weltmeister trans mounts?
I am SO not showing you the pics of my audi conversion
I should expand on my statement.
I used a pair of those solid mounts in my own race car at one time.
They are an appealing product because people think that installing solid transmission mounts is a performance upgrade, and the Weltmeister pieces are relatively inexpensive.
My experienced opinion is that one end of the engine/trans mounting system should remain flexible, even if only to a small degree - at least in all but the stiffest of racing chassis'.
I prefer to mount the engine end solidly and the trans end on stiff rubber such as 911 sport mounts or WEVO mounts.
The Weltmeister pieces don't stay tight in hard usage. The magnesium trans ears will fret on the hard plastic and cause erosion.
As with the majority of components bearing that brand, in usage the actual product leaves much to be desired.
