My 914 has a brake fluid leak under the master (little drips on the ground!) now I may only have a leak in the hoses to the master, but the master in the car is old, so I am trying to budget for the worst case.
I looked and found these options at Rock Auto. has anyone experince with these masters, there is a URO brand one, (maybe a six cylinder version), there is a 23 mm one (to big??) from URO, a cardone rebuilt one, and a Raybestos one.
Any suggestion about quality of these parts or suggestion for alternate vendors?
there is a huge price differance, $71.79 to $239.79
From Rock Auto website.......
1972 : PORSCHE : 914 : 1.7L H4 : Brake/Wheel Hub : Master Cylinder Price Core Total Add to Cart
ÜRO PARTS Part # 91135501202 More Info Brake Master Cylinder
6 Cylinder; Pressure switch is included
$71.79 $0.00 $71.79
ÜRO PARTS Part # 91135501202A More Info Brake Master Cylinder
6 Cylinder; Big Bore; 23mm high performance version
$84.89 $0.00 $84.89
A-1 CARDONE Part # 114427 More Info Reman. - Return and Rebuild Service Only - By ordering this service you are agreeing to send your original part to the manufacturer to be rebuilt. Rebuild time is approximately 3-5 business days. You will be contacted with directions once the order is placed. For more information please contact Customer Service.
without Stoplight Switches on Master Cylinders; Power brakes
$90.79 $18.00 $108.79
A-1 CARDONE Part # 113740 More Info Reman. - Return and Rebuild Service Only - By ordering this service you are agreeing to send your original part to the manufacturer to be rebuilt. Rebuild time is approximately 3-5 business days. You will be contacted with directions once the order is placed. For more information please contact Customer Service.
without Pressure Sensor
without Stoplight Switches on Master Cylinders; Manual brakes
$143.79 $18.00 $161.79
RAYBESTOS Part # MC39290 More Info Professional Grade; Bore Size=11/16" Number of Ports=2 Primary Outlet Size=M10x1
Except Pressure Warning Switch; Power brakes
$239.79 $0.00 $239.79
