krazykonrad
Jan 23 2012, 03:43 PM
I'm wanting to remove my oil pump to see what cam I have. I've loosened the 4 nuts, but no movement. What do I need to get this done?
Thanks,
Konrad
Cap'n Krusty
Jan 23 2012, 03:48 PM
Pry it out using the two handy dandy tabs made just for that purpose .........................
The Cap'n
ape914
Jan 23 2012, 03:54 PM
Type I or TypeIV pump? either could be installed in the type IV motor. the type IV pump has tabs to pry from, the type I does not and if stubborn you need a VW Bug style pump puller.
since TypeIV pumps are no longer produced, many folks switch to the type I pump if it is worn out. This also offers the option of high capacity pumps (larger gears)
Dave_Darling
Jan 23 2012, 05:53 PM
People often have to loosen up the case through-bolts above and below the pump. It's a very tight fit in there, and any sealant just makes it harder to get out.
--DD
krazykonrad
Jan 23 2012, 08:44 PM
Thanks for the advice. I did some prying before, but I am worried about prying too hard. At what point should I leave well enough lone?
Thanks,
Konrad
