Mikey914
Feb 2 2012, 12:51 PM
OK,
Looks like enough interest to put these back in production. They will be $115 + shipping. This is the airdam only.
I am re-valuating the rubber for these also. Before there just wasn't enough demand to produce it. But, if I can get 25 firm orders at $49 for the rubber only. I will make it. After the GB I would sell at $65, as these are a heavy rubber part
The airdams can be produced in a few weeks easily, but the rubber will require me to make a die and run it which is usually a 6-8 week process, so I will have one before the other, if there is enough interest.
The rubber will be retrofittable to the old dams, so if you have one (and I know there were a few out there) and need the rubber, you can buy just the rubber
So if you are interested post here what you want.
thx
Attched are pictures of one on my old car.
BTW- don't you love it when the new owner loves to taunt you by sending pictures like this.
VegasRacer
Feb 2 2012, 01:00 PM
I'll take 1 with rubber.
MoveQik
Feb 2 2012, 01:02 PM
Mark, your pic is a little dark. Can I assume it is the same spoiler pictured below from the other thread?
Rand
Feb 2 2012, 01:03 PM
I've always loved that setup with the rubber skirt. I would definitely be in for both airdam and rubber.
(Shout out to Rhodyguy, who gave me one of those fiberglass parts at a Seattle swap meet a few years back. Thanks Kevin, always appreciated that. I had to let that car go when I moved.)
Mikey914
Feb 2 2012, 01:10 PM
Yes,
Tom found an old one that was useable and mounted it. Here's a better before.
tradisrad
Feb 2 2012, 01:12 PM
I may be in for an air dam with the rubber.
Mikey914
Feb 2 2012, 01:35 PM
Not a pretty as this one, but I really liked this picture.
JmuRiz
Can the rubber be added/removed as-needed?
Say you wanted to run w/o the rubber on the street (curbs/driveways etc) and with the rubber at the track.
Tom_T
I sent you a SOT but related PM.
Tom_T
Feb 2 2012, 01:39 PM
QUOTE(JmuRiz @ Feb 2 2012, 11:35 AM)
Nathan,
The idea of the solid rubber ones made back in the 70's & 80's was to have it flex rather than break on parking lot wheel bumpers, curbs, low approach aprons on driveways, etc.
So I would assume that Mark is talking about a solid & fully flexible one for either street or track/AX for that reason - not a removable rubber cover.
Elliot Cannon
Feb 2 2012, 01:43 PM
I'll take one with rubber as well. PM me an address and I'll send a check for what ever the total is.
Cheers, Elliot
aharder
Feb 2 2012, 01:44 PM
Mark,
I would be in for 1 Air Dam.
Thanks.
Allen
Jeffs9146
Feb 2 2012, 01:49 PM
I am in for one no rubber please!
VaccaRabite
Feb 2 2012, 02:14 PM
I've got one of these units on my car and can testify that they are great.
Zach
MartyYeoman
Feb 2 2012, 02:15 PM
Put me down for 1ea. rubber only.
Thanks, Marty
TC 914-8
Feb 2 2012, 03:10 PM
I bought one of marks Flexdams 2 years ago. It came with rubber which I mounted with separate brackets so I didn't poke holes in the fiberglass. I posted a few pictures back then but here is a few more.
Thanks Mark, hope all is well.
Click to view attachmentClick to view attachment
wingnut86
Feb 2 2012, 03:11 PM
Mark,
Job interview on 2/10. Afterwards if I'm offered, definately want the kit w/rubber...
Mikey914
Feb 2 2012, 03:14 PM
To clarify the part about being able to remove the rubber for the street, Yes, you can. The issue is the holes in the fiberglass that you would see. I guess they could be addressed with some type of plug. The bumper would come undrilled and I'm sure I could put together a hardware kit for mounting.
-Mark
Feb 2 2012, 04:05 PM
QUOTE(Mikey914 @ Feb 2 2012, 10:51 AM)
Looks like enough interest to put these back in production. They will be $125 + shipping. This is the airdam only.
Stupid question, since i haven't looked at a stock frontend in forever. Where the air-dam mounts, is there enough space behind it to run brake ducts?
Or is there sheetmetal behind most of the air-dam?
Mikey914
Feb 2 2012, 04:26 PM
This actually mounts on the tabs that the OEM lower metal cover would mount, there is pleanty of room behind it.
a914622
Feb 2 2012, 05:05 PM
Im in for one airdam if i can come pick it up? No shipping .I need a reason to run south!
Jcl
Mikey914
Feb 2 2012, 05:18 PM
I would just as soon not ship, but I have learned that custom boxes make life much easier.
So, yes pick up is fine.
Feb 2 2012, 05:21 PM
Hmmm, i'd have to have a close look at one mounted on a car to see if there's room to mount brake cooler ducts to the spoiler.
If so, i'm in for a spoiler AND the rubber bottom ...
jmill
Feb 2 2012, 05:49 PM
Is the spoiler glass? I have a flared car and would need to tweak it a bit. Do you give extra rubber so I could trim to fit??
Kargeek
Feb 2 2012, 06:39 PM
Click to view attachmentClick to view attachmentIf you tool up to make these, add a an inside fender lip to match the one on the fender.
scottb
Feb 2 2012, 06:49 PM
QUOTE(Kargeek @ Feb 2 2012, 07:39 PM)
the short skirt is nice on this one....
rktmn247
Feb 2 2012, 08:53 PM
QUOTE(TC 914-8 @ Feb 2 2012, 11:10 AM)
Click to view attachmentClick to view attachmentI am interested also. Looks like your car has flairs. How did you mod to fit? Is that the same one as in your avatar? Mikey how much to ship to Hawaii, with and with out the rubber?
JStroud
Feb 2 2012, 09:43 PM
I'm in for one, no rubber.
Thanks
Jeff
Jeffs9146
Feb 2 2012, 10:08 PM
I am noticing that you must be reproducing these from the original that is posted on my car?
Is this the same one that is mounted on the silver one? Notice the end of the Dam is squared off and the one that others are showing is not!
Which one will we be getting?
First photo is the one I want and the second I will need more details and the third one just looks different!
Maybe they modified the second one for the flairs??!
Mike Bellis
Feb 2 2012, 10:33 PM
I have one too. It can be spread a little for a flared car. I did cut a releif in both corners so it wouldn't crack...
Elliot Cannon
Feb 2 2012, 10:53 PM
QUOTE(Elliot Cannon @ Feb 2 2012, 11:43 AM)
Cheers, Elliot
Because I want one right NOW!!!
shoguneagle
Feb 2 2012, 11:54 PM
I am into getting a rubber one. Please put me on your list and let me know when and how you want the money.
Steve Hurt
aharder
Feb 3 2012, 12:09 AM
QUOTE(aharder @ Feb 2 2012, 01:44 PM)
Mark,
Thanks.
Allen
Ok, I'm changing my mind
That Rubber looks good so I'm in for including the rubber on mine.
Mikey914
Feb 3 2012, 01:19 AM
The one that I have tooled up for is this one. We didn't add any cooling ducts, or make larger edges for flairs, however they can be modifed as some of my customers have done. The problem with setting up for flairs is that there are 2 differnt manufacturers of the steel, and also fiberglass ones. I don't have a way to assure the fit, so I made the tooling with a netural blended edge. It can be modified. It's just a matter of cost, and I'm trying to keep the cost down.
SLITS
Feb 3 2012, 08:06 AM
One with rubber ...............
Jeffs9146
Feb 3 2012, 10:11 AM
QUOTE(Mikey914 @ Feb 2 2012, 11:19 PM)
OK so it is no longer like the one on the my old silver car with the blocked edge!
It now has the smoother ends??
Feb 3 2012, 12:11 PM
QUOTE(Jeffs9146 @ Feb 3 2012, 08:11 AM)
That's what it looks like ...
I'd be interested in a version that is a bit taller and has brake ducts and a oil cooler cutout and flared ends and a larger rubber lip.
amphiduck
Feb 3 2012, 12:25 PM
I'd be in for one without rubber. What's the damage on getting one to TN?
Mikey914
Feb 3 2012, 12:26 PM
Yes you can see how the edge is less defined, this is how we made the molds. The blocked edges could be done with some retooling but would add significantly to the cost. I'm trying to keep the costs down on these as much as I can. As well as keep confusion down.
BTW I was able to reduce the cost to $115.
pilothyer
Feb 3 2012, 02:09 PM
I am in for one with rubber and one with no holes, no rubber.....Thanks again Mark for making these................Jerry
ottox914
Feb 3 2012, 04:21 PM
Count me in for one with rubber.
-Dave
Robert21
Feb 3 2012, 09:42 PM
I would buy one looks great Robert21 with rubber thanks
Porschef
Feb 4 2012, 07:34 AM
+ 1, w rubber...
DBCooper
Feb 4 2012, 07:44 AM
QUOTE(Mikey914 @ Feb 3 2012, 10:26 AM)
You sure have this board figured out.
FlatIV
Feb 5 2012, 08:57 AM
One of each, please.
Mikey914
Feb 5 2012, 11:22 AM
Looks like about 14 for sure and about 6 maybes for the fiberglass portion. I was able to get the cost down from $125 to $115 as it looks like there will be some quantity.
Looks like 19 rubber sections.
Just to clarify, the rubber is added to the fiberglass section, you don't need to have the rubber, but you need the (or a ) fiberglass part to mount the rubber to.
looks like we are close enough that the rubber will get made, just need to get 6 more commitments to make it pencil out, and I'll bet there are enough older airdams that need it that we can pick up the balance.
I'm having custom boxes made for these so that they can ship easier than last time. I can't see the shipping being more than $30 as an average
jsayre914
Feb 5 2012, 11:59 AM
Im in for 1 airdam and the rubber
FourBlades
Feb 5 2012, 02:48 PM
In for 1 plus rubber!
John
lonewolfe
Feb 5 2012, 02:55 PM
I'll take one with rubber too! Keep me posted on the details. Thank you!
streetrover
Feb 5 2012, 03:36 PM
Count me in for the fiberglass air dam only. Any idea about shipping cost to So Cal (92344)?
