flipb
Feb 6 2012, 02:05 PM
Hi,
I decided to take a drive on Friday... hopped in, got all ready to fire up... pumped the throttle as I always do, and snap - tension releases as the throttle cable lets go.
Upon investigation, it separated at what appears to be a crimped connector near the carb linkage. Never noticed the connector before, but perhaps when I switched from Progressive carb to dual 40's, my mechanic had to crimp on another few inches of cable?
anyway, I can easily fit the loose end back inside the connector. My questions are:
1. Should I just insert it, crimp the connector, and call it a day?
2. Should I add anything (loctite, gorilla glue) and then crimp it?
3. Should I consider this a temporary fix and replace the whole cable ASAP? Or will this DIY job last if done properly?
914Mels
Feb 6 2012, 04:25 PM
If your crimp connection just pulled apart and the cable insn't damaged, you could get a new correct sized sleeve and re-crimp it or use a barrel clamp like the heater cable uses at the heater box. Just make sure to adjust the throttle stop so your not over stressing the cable.
flipb
Feb 10 2012, 08:35 AM
OK, so this morning I went out to re-crimp the throttle cable connector... and discovered that it's not the type of connector that one would crimp. Guess I didn't look closely when I found the break.
Attached are photos. How is this type of connector supposed to be fastened? How can I DIY? I'm supposed to bring the car to the shop this afternoon (for several things, perhaps to include a new throttle cable!) and I really don't want to deal with towing for something so simple.
Click to view attachment Click to view attachmentSorry 'bout the grimy engine... she's a driver.
TheCabinetmaker
Feb 10 2012, 08:42 AM
Far from a cable expert, but that just don't look right. From the pics it appears the cable has broke and this is a repair attempt. Its gonna break again. Buy a new one. Oh, if I'm correct, and your mechanic did this? find a new mech.
flipb
Feb 10 2012, 08:54 AM
I need to make it about 5 miles.
Can I just loop some wire through one of the end holes on the linkage connected to the hex bar, then barrel-clamp it (or somehow fasten it) to the good end of the cable?
TheCabinetmaker
Feb 10 2012, 09:10 AM
I'm sure you could if you don't stomp on the pedal too hard. I've removed the lid and ran a wire into the cockpit and used it as a hand throttle to get me home.
flipb
Feb 10 2012, 10:21 AM
I know you're all at the edge of your seats, waiting to see how I solved this problem...
My philosophy of DIY: If it can't be repaired with zip ties, take it to a professional.
Click to view attachment Click to view attachmentI pumped the pedal a few times and it seems like a decent connection. We'll find out in a little while. To be safe, I'll take the flatter / less hilly route to the shop - don't want this to pop while I'm halfway up a steep hill.
76-914
Feb 10 2012, 10:34 AM
Take Clay's advice. Bring a long piece of string or wire.
TheCabinetmaker
Feb 10 2012, 10:58 AM
QUOTE(76-914 @ Feb 10 2012, 10:34 AM)
When did Clay sneak into this thread?
