Well,. . . . .
A CGI did in fact break out in my shop last night. I would have to give last nights a show about a 6. Decent beat, but tough to dance to.
Got last bits & pieces assembled pretty smoothly. Spent a good hour carefully filling and burping the cooling system, and I am pretty confident I was able to 98% if not 100% of the air out of the system. Time to turn the key. . .
I left the coil wire off first, to get the oil flowing a bit before starting. Turn the key, engine turns over nicely.
So far so good. Put the coil wire back on, time to start 'er up. Turn key, engine turns over, . . . and over. . . . and over. Hmmmmm. I smell gas.
Guess I flooded it when I rolled her over w/o the coil. Pedal to floor, turn key, turn, turn, pop, turn, pop, pop, turn, VROOMMMMMM!!!!!!
YEAH BABY!!!!!!!
I run it for about a minute at 2000, shut it off. While it was running, the oil pressure is pegged at 80 psi, and I'm thinking that is probably a wiring issue. I needed to get the oil into filter and what not, but shut it off and check the oil level right away so I can make new marks on the dip stick due to the goofeyness with the hole being different than usual in the block. I do that, and wait for my wife to come out so she can hold the engine at 2000 while I sniff things out, and maybe try to ear the timing a little tighter. She comes out, I try to start again. Same issue, floods easily and quickly. I leave the key in the on position while we talk about something or other for a minute(thus fuel pump running), and now I REALLY smell gas. I get out and look at the engine, find gas dripping out of the carb in multiple places. WTF???
Looks like the float must be stuck open.
Give the bowl a few good sharp whacks with a wrench, turn on key, looks to be ok. Start her up again. Starts easier this time, Beth holds the RPMs while I just look every thing over. I look closely into carb, and it's got a drippy dick going into one of the round bowls (secondary?), but engine is running smoother as the time passes, so I decide to keep it running. I flipped the poles on the oil pressure sender, and now it looks like an actual reading, but is still about 55-60 psi. About Seven minutes in, I see one of the header pipes is starting to glow a bit.
It was cool here last night, so the water temp was fine at all times, never getting above 190. I'm thinking this glowing business could be due to timing not being quite on, as well as probably running rich due to the gonorrhea jet, but I'm not comfortable keeping her going like that, so I shut it off.
Then I think I should check the oil, and sure enough, it smells like gas a bit, so it has become fouled with gas running through the intake. Stef couldn't come out last night, but he calls right about then for an update. I tell him the whole deal, and he's not the least bit worried about any of it. He says the header is almost certainly due to the carb being funked up, and the timing. As far as the carb, he is sure we can get it sorted out tonight, and in regard to the oil pressure, well, we will figure that out too. So, I will change my oil with about 8 minutes of running time on it, and we will attack it fresh tonight. I'm sure with my guardian master mechanic present, things will go better tonight.
