Nozzle
Feb 23 2012, 11:37 AM
OK all you Raiders of the Lost Teener, I finally got up the courage to take the passenger side valance off to see what I was going to find and like so many I found this:
Click to view attachment As luck and the good old California climate would have it, the rust seems manageable I hope. The problem is there is some rust at the seems and under the jacking point but I'm not sure how to proceed to get it under control. Here's some close-ups:
Front aft of the wheel well
Click to view attachment Mid span (notice two-tone paint..?
Click to view attachment Jack point
Click to view attachment Any advice would be much appreciated.
Thanks,
John
76-914
Feb 23 2012, 11:44 AM
Looks good. You do know that this is porn for the "east coasters".
jonferns
Feb 23 2012, 11:45 AM
It largely appears to be superficial. It does appear however that the jackpost is full of crud, which probably held water and allowed it to rust from the inside out. Scrape and poke at that rusty spot at the bottom of the jackpost and see if it opens up. Looks pretty good though.
VaccaRabite
Feb 23 2012, 11:54 AM
What rust?
*grumble grumble lives on east coast grumble*
billh1963
Feb 23 2012, 11:56 AM
QUOTE(Vacca Rabite @ Feb 23 2012, 12:54 PM)
What rust?
Really...I'm thinking "sheesh....are you kidding me?"
Eric_Shea
Feb 23 2012, 12:01 PM
Looks amazing. That said, I would find a really qualified welder and get that jack post off - clean everything up - and weld on a new one.
This is how it begins. And, that packed in crud is sitting against your long. Couple hundred now. Couple thousand later.
Eric_Shea
Feb 23 2012, 12:05 PM
On second thought... it's so clean, maybe just cut along the triangulated edges, clean and rust proof and re-weld what you have there.
Very nice - Again...
jonferns
Feb 23 2012, 12:25 PM
QUOTE(Eric_Shea @ Feb 23 2012, 01:05 PM)
carr914
Feb 23 2012, 12:43 PM
QUOTE(billh1963 @ Feb 23 2012, 12:56 PM)
What rust?
76-914
Feb 23 2012, 12:45 PM
I'll see your pile of dirt and raise you one Dr. Pepper can.
porbmw
Feb 23 2012, 12:53 PM
Incredibly dry and clean! I don't think they get much better than that...
I do have a related question....
The factory appears to have supplied one drainage hole.
The photo seems to show that the rust may be greater on the right side, opposite the hole.
Would it make sense to provide an additional drainage hole on the opposite end....or would this invite more dirt, debris, moisture....and be counterproductive...?
Eric_Shea
Feb 23 2012, 01:26 PM
I'd do it like the front section. See the previous picture. Two holes down low.
Nozzle
Feb 23 2012, 04:45 PM
Well after taking a dental pick to the jack point drain hole the story became clear. Lots of rust flakes coming out with the dirt. So getting my courage back I got the left valance off and the two bumpers. Much the same story but some bad rust just in front of the front trunk lid.
Guess it's time to see if Scotty B. has any time available this Spring...
Left jacking point actually seems to have more rust inside the jack than the passenger side.
Click to view attachment Front rust just under the trunk lid, not through and through yet but will be given time
Click to view attachmentRear looks pretty good
Valy
Feb 23 2012, 05:02 PM
Your car is perfectly fine for its age. Stop screwing around!
TargaToy
Feb 23 2012, 05:49 PM
QUOTE(Nozzle @ Feb 23 2012, 12:37 PM)
... the rust seems manageable ...
Braggart!
RUST??? I have more rust than that in my ears when I finish up working on mine on Saturdays.
rgalla9146
QUOTE(Valy @ Feb 23 2012, 03:02 PM)
I'd cut the bottom off at the lower edge of the tube, check out the inside, if solid treat
the rust and put a new bottom on. Some careful grinding and it can look like nothing ever happened. Then flood the inside with some preventive again.
While your at it repair the top of each tube. They appear damaged from jacking without inserting the jack fully.
carr914
Feb 23 2012, 06:12 PM
Dude, your car has No Rust, quit fuchin around. Nothing there for Scotty to do that you can't do in a 1/2 hour.
Germancar-Junkie
Feb 23 2012, 06:19 PM
Woah, that thing is horrible. You should unload it ASAP. (but let me know first before you do that.)
Socalandy
Feb 23 2012, 08:42 PM
I agree with Eric, My 72 looked like yours and we opened the bottom of the jack point and cleaned it out and closed it back up. This is my current project and shows what time will do to this area and how it may be worse inside
balljoint
Feb 24 2012, 08:45 AM
QUOTE(Nozzle @ Feb 23 2012, 05:45 PM)
That is exactly what you do. Get a pro who knows the car to fix you up now. The job will be cheaper and faster now and then you can brag aboot your body man, and if he puts an extra drain hole in there for you then you have custom work done. Sweet.
rallysport70
Feb 24 2012, 11:41 AM
Jealous!!! You have no idea.....
GaroldShaffer
Feb 24 2012, 12:03 PM
Mine looked simular to yours, I opened mine up just to see how bad it was inside and was lucky that all it did have was some surface rust. I ended up buying the jack plate cover from restoration design and had Brad Mayuer's shop do the replacing since I am not a welder. Money well spent in my book because I know it is fixed correctly. I also remove my rocker panels twice a year to clean all the crap out from behind them. Simple insurance to make sure the rust demon doesn't return in the jack post area.
Here is how mine looked before the repair ad after I opened it up. Both sides looked almost the same.
