Full Version: oil cooler brackets
machina
There are a pair of coolers, these brackets were 4 hour to fab, about 3.5 hours longer than I planned. Gotta do the second set sunday.
Planning on mounting coolers out back. If they work out I'll let you know.
dr
echocanyons
Looks good are you mounting it under the trunk?
lagunero
Very nice! Out back...where?
MXMARK
Looks great, good luck. Mark
machina
QUOTE(lagunero @ Sep 11 2004, 06:10 PM)
In the are where the stock muffler is located. Removed the old brackets. Don't plan on running at idle more than 1 minute, on the grid or in the pits.
I think there will be quite a bit of airflow back there between 80 => 130 mph.
I am prepared to move them or duct them if there is not enough cooling capacity.
Won't know till she runs at speed.
dr
Jeroen
Hard to see in the pic, but are you using any rubber insulators between the mounts and the cooler?
Pieces look very nice (just like the rest of you car)
machina
QUOTE(Jeroen @ Sep 11 2004, 06:37 PM)
Yes,
rubber spacers at each of the 8 mounting points. They are not in the picture, waiting on proper hardware from the UPS man.
dr
