Full Version: Quick question
MattR
Can anyone tell me what holds on the shroud around the steering column?
qa1142
Housing is one piece. You have to pull column and take guts out. From what i hear, it is easier to just get a newer column than to fix them. Early 70-71 are hardest to work on
Aaron Cox
so there is now way to take the "shroud" off
sj914
You can't take apart the shroud, but you can take the stuff out of the shroud. wacko.gif
Dr Evil
Shroud is held on by one bolt under to the left. You can remove everything from it and then slide it off.
HTH
Aaron Cox
QUOTE(Dr Evil @ Sep 13 2004, 09:19 PM)
HTH
thanks
maf914
I've had mine apart a couple of times for replacement of the ignition switch. Follow the Haynes manual procedure for steering wheel and column removal, page 105. It won't be very clear when you begin, but you can figure it out. When you finish it still won't be clear. laugh.gif
aircooledboy
Try this link:Bird ignition switch article
Was pretty helpful to me.
Dr Evil
I'll do one better for ya. Here is the bottom view of a removed steering column. You can see the single 8mm(?) bolt that holds it on.
Dr Evil
After you remove the guts (4 screws that hold in the switch assemblies), and remove the cover for the ignition switch you can slide the collar off of the shaft. In the picture is my bearing as well, but you dont need to remove this unless there is a reason.
Dr Evil
don't touch the bearing, you don't need to. Did you remove the ignition switch? If yes then just tug on it. It is hard to get off. Just wiggle it back and forth. It is an interferance fit at this point.
HTH
Aaron Cox
it came off. what a PITA. cleaned it up, looks like new (gloss black)
thanks for your help
Dr Evil
What, are you copying me punk?!
Aaron Cox
QUOTE(Dr Evil @ Sep 14 2004, 07:55 PM)
no. youre copying me! It looks better than new now! thanks for the idea!
p.s. : hows "the stuff" ?
redshift
Dood, NOTHING looks better than new, you should have seen these things when they were new... it's fun to walk down a row of ones that smell new.
oh jeees... wow..
m
Dr Evil
Shhhh, I'll have it for you this weekend.
