QUOTE(falconfp2001 @ Mar 15 2012, 04:04 PM)
Very Nice. Besides being able to monitor CHT on all for cylinders, does MS have the ability to tune to four CHT inputs?
Maybe MS 3?
Out of the box, Micro/Megasquirt, like most EFI systems, performs the fuel injection calculation based on a single engine temperature input. For water cooled engines, it's coolant temp; for air cooled engines, it's cyl head temp. There may be other temp sensors, like an air temp sensor, that go into the injection calculation as well...but there is only one *engine* temp input.
It doesn't matter where (within reason) you're measuring engine temp for this calculation as long as you tune the fuel map to the location at which you're measuring. However, for *monitoring the health* of the engine, you need to measure at the hottest spots...under the spark plug.
I suppose if you were running sequential (not wasted) spark, sequential (not batch) injection, and had individual CHT and/or AFR and/or EGT sensors for each cylinder, you could somehow adjust the mixture for each cylinder. No EMS system that I know of supports this out of the box; however, I guarantee you that you could make a system that would do it. Some combination of MS3 and MSExtra components may get you there.
Unless you are planning to run the engine at 99% of its performance envelope for an extended period of time (a purpose-built motor to set a land speed record or something), this level of cost, control, and complication seems excessive. But, it would be wicked fun to try and build it!!
As far as the group buy...I'm in given my recent experience...although the thought of ripping my interior apart AGAIN to run MORE wires makes me sad.
