QUOTE(watsonrx13 @ Sep 19 2004, 02:30 PM)
So you didn't make a template?
Instead, you took the old fender and placed it 'inside' the new fender then started cutting, carefully?
This is almost exactly how I did it. I laid the black fender over the top of the remaining green fender and then scribed a line on the inside of the fender. I then cut close to the line (not exactly on the line) and held it up again. Each time you cut material away you can get a more accurate line. Each time you can cut closer to your latest line with confidence. I probably did this 6-8 times. Once it gets really close I used an angle grinder with a grinding stone to finalize the line. Grinding a bit at a time. The line is a guideline always, never a cut line. The line shows you how close you are, not where to cut. Never cut exactly on the line. Go slow, do it slowly and painstakingly. The more time you spend here, the easier it is later and the better job you'll do over all.
One last tip, make sure things fit up 100% without having to force anything into place before you start welding. If you can hold the piece in place with two fingers and have it line up on its own, then you're going to do a great job. If you plan on welding a little and then bending or forcing or hammering things as you go you're going to make crap. It's all about the prep work, not the welding.
