Full Version: What FI system should I install?
lagunero
I need to make a decision soon. Assuming I can afford it, what system would you recommend for someone who doesn't want (nor is capable) to fiddle with fuel management systems? I have a 2.0 long block that I'll be getting to soon. I don't mind changing the internals. My goal is to have a reliable set up. I do not have a harness or injection system other then the one on my 1.7. I've looked at the websites for Megasquirt and KitCarlson but both seem to be for the serious DIY''er. I didn't mind carbs before but I just don't have the time to waste on them anymore.
HP or economy are not the issue, reliability is.
Thanks and.....HELP!
lapuwali
Actually, the Kit Carlson system is likely to be your best bet. The MS requires full assembly (soldering), as well as setting up the fuelling maps. Very much a DIY prospect, and not suited to someone who isn't interested in that. The Kit Carlson system, on the other hand, was developed on the T4 engine, and is supposed to be pretty much a plug-and-play deal. It's not available, yet, so other than Kit and Jake, no one here can really attest to just how plug-and-play it is. If it's everything they say it is, it's going to be the easiest and most cost effective system to live with and convert back to EFI from carbs, assuming one doesn't have a complete, working stock system.
One shouldn't discount the original system, either. The parts for it are available, and there are replacement harnesses available. Some of the items are fairly expensive (rebuilt MPS, for example), but paying someone else to fit any of the aftermarket EFI systems will cost considerably more.
TimT
I have webers on my /6 simple and reliable...whats wrong with carbs?
btw your calipers went out on saturday.. Ill try to get a tracking number
lagunero
Thanks guys. That's pretty much the conclusion I had come to but like they say, you ask advise when you know the answer but want someone to tell you otherwise. I hadn't ruled out the stock FI but I wasn't sure just how wise it would be if a different system was out there and I just wasn't aware of it (seeing that I'm starting from zero).
Nothing wrong with carbs. It comes down to the best investment for 914 owner laugh.gif
I also forgot to mention that time is extremely limited for a while so learning how to DIY is not an option right now. It's either drive the car or work on it idea.gif I'll take option #1! Thanks again.
Mark Henry
I have the SDS system. The install was straight forward except for the crank trigger (you don't "have" to have crankfire) set-up.
Cam choice is important with PEFI, although my SDS hates the crappy Scat C-25 I have now I got it running real good, least better than carbs. I'm going to hit Jake up for a cam when I do my new engine this winter.
As far as programing goes...that was the easy part with my SDS.
you can see my install at:
http://www.914world.com/bbs2/index.php?act...t=ST&f=2&t=5396
and the update at:
http://www.914world.com/bbs2/index.php?act...t=0#entry204559
lagunero
Thanks for the info. It seems that you have worked the bugs out.
mike_the_man
From everything I've heard, the Kit Carlson system will be the way to go. From the sounds of it, it will just plug into the existing system, using the stock sensors and injectors. I'm not too sure on the price, but I know that Jake has been testing it, and he had nothing but positive things to say. It may be worth the wait!
Jake Raby
No serious DIY on the Kit Carlson system..
The way we'll be selling it all you do is hook up the harnass, you can even use stock injectors and etc..
I can attest to how easy it was, even a test system with a test harnass and brain. We installed it in one day on my 912 and did so from carbs.
Still no issues and 4,000 miles on the system so far
tommy914
QUOTE(Jake Raby @ Sep 20 2004, 10:37 PM)
Jake,
How much longer before we can order one of these??
Elliot_Cannon
It looks like by the time you get a FI system you might have time to wash and wax??
Cheers, Elliot
Jake Raby
They are being produced in a more mass quantity now. I think Dave has to get some insurance and paperwork things settled before he will sell a system.
I would estimate some time before Christmas to be selling them, but thats all according to testing on some more engines here at the shop...
lagunero
Great news on the expected release! If this is true then I can prep to build my engine for carbs or the Kit. All in time for Xmas!
