| lagunero |
Sep 20 2004, 05:38 PM
Donkey Member ![]() ![]() ![]() Group: Benefactors Posts: 1,042 Joined: 8-January 04 From: orange county,ca Member No.: 1,531 |
I need to make a decision soon. Assuming I can afford it, what system would you recommend for someone who doesn't want (nor is capable) to fiddle with fuel management systems? I have a 2.0 long block that I'll be getting to soon. I don't mind changing the internals. My goal is to have a reliable set up. I do not have a harness or injection system other then the one on my 1.7. I've looked at the websites for Megasquirt and KitCarlson but both seem to be for the serious DIY''er. I didn't mind carbs before but I just don't have the time to waste on them anymore.
HP or economy are not the issue, reliability is. Thanks and.....HELP! |
lagunero What FI system should I install? Sep 20 2004, 05:38 PM
lapuwali Actually, the Kit Carlson system is likely to be y... Sep 20 2004, 05:53 PM
TimT I have webers on my /6 simple and reliable...what... Sep 20 2004, 06:03 PM
lagunero Thanks guys. That's pretty much the conclusion... Sep 20 2004, 07:39 PM
Mark Henry I have the SDS system. The install was straight fo... Sep 20 2004, 08:00 PM
lagunero Thanks for the info. It seems that you have worked... Sep 20 2004, 09:25 PM
mike_the_man From everything I've heard, the Kit Carlson sy... Sep 20 2004, 09:35 PM
Jake Raby No serious DIY on the Kit Carlson system..
The wa... Sep 20 2004, 09:37 PM
tommy914 ![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 10:25 AM |
