I'll take some picks tomorrow after wiring it up.
This is the Innovate MTX-L. Over all length was 12' and it fit perfectly from the muffler all the way to the dash. I'm going to mount the Gauge off of the Ash Tray.
I wired it using switched 12v from the Fuse Panel under the dash. The fuse panel is setup to have power flowing from top to bottom and there are several open spades for adding accessories. Or just buy a spade jumper at a local Auto Parts. Be careful as all the red wires to the right on the fuse panel are hot without the key on. I used a circuit tester that I ground, then tested the next fuse left of the last red and it was cold. Turned the key to on, and it was hot. It had an open spade connection so I crimped a female spade and plugged it in.
With this Gauge, you have to also find the headlight source which is a yellow wire off the fuse panel but I just crimped a female spade and plugged in to the open connector next to it because they are both hot when the headlights are on and cold with them off. The purpose of this is to dim the gauge when it is dark out. I'll test and calibrate tomorrow.
Just got the O2 sensor calibrated and the Gauge mounted and wired. Looks nice. If I add another Gauge later I'll get the combo panel. Right now its the only extra Gauge I have but looks good.
As soon as I wired it up, I noticed my AFR was way off (as I suspected after my last visit to my Mechanic) so, I did some adjusting after I warmed up the engine.
Couldn't get the mixture right with my ECU idle mixture knob so I moved on to the fuel pressure regulator. Not surprisingly the mounting nut for the regulator was loose (must have been the mechanic). So, I tightened that, loosened up the lock nut on the adjustment bolt and adjusted to get the right AFR. Some of you are probably cringing right now because I didn't use a pressure gauge. I'll do that later.
I then let the car idle for about 20 minutes, then revved to 3000 and held for five minutes. idled for five, revved for five, idled for five. All while checking the AFR.
Engine was ate peak now and I was able to then adjust AFR with the ECU and the idle speed with the control screw on the TB.
Runs better.
