kwlane
Mar 18 2012, 10:41 PM
Is there some trick I'm missing about getting the parking brake handle off its support? Can't seem to find anything in Haynes or Hussey's book. Last time I tried this I ended up drilling out the retaining ring. However, don't want to screw this one up.
reharvey
Mar 19 2012, 03:09 AM
You have the bolt out so it should slide right off the pin but it's stuck because of all the rust. Spray it with lots of penetrating oil and let it soak in. Wiggle it up and down while using a large screw driver from behind to force it off.
kwlane
Mar 19 2012, 08:24 AM
Thanks, that is what I thought so will apply more force now!
