worstmanassoc
May 7 2003, 05:27 AM
I wanted to upgrade my rear brakes to the 4 piston type. (i.e. 944 Turbo type) However, it is my understanding that if you do this you loose the E-Brake. So if I stay with a stock caliper on the rear is there any way to do cross drilled vented rotors? Does the 914-6 stock setup allow for rear vented rotors?
VegasRacer
May 7 2003, 05:38 AM
Why do you think you need bigger brakes on the rear?
What do you have on the front?
Who need an E-brake?
(a hunk of 2 X 4 works great)
Don't know if the 6 rears are that much better than the 4.
Just more $$$'s.
914Timo
May 7 2003, 05:43 AM
You can use 911 E-brakes like I do. The cables are the problem. Otherwise it is pretty simple conversation. You need to modify the trailing arms a little to be able to bolt the back plate to the trailing arm.
brant
May 7 2003, 08:41 AM
I've had 2 different rear brake set ups with vented rotors...
for what your talking about... Split the calipers. Have spacer blocks machined. Rebuild the calipers with new o-rings. buy some 911 rear rotors..
viola.. vented rear brakes with parking brake..
(Oh I forgot to mention that these are totally unnecessary)
brant
Brad Roberts
May 7 2003, 10:24 AM
Welcome "WorstMan"
You live where I spent 20+ years of my life (Arlington)
I'll start by asking you what you have on the front of the car currently.
B
VegasRacer
May 7 2003, 11:06 AM
QUOTE(VegasRacer @ May 7 2003, 03:38 AM)
Hey - I'm smarter than I thought.
My question was the same as Brad's.
(not that I have the right answer when responds)
Bleyseng
May 7 2003, 01:33 PM
Brad, he wants to do 180's everytime he steps on the brakes...
Geoff
jonwatts
May 7 2003, 01:57 PM
Timo, you have rear drum brakes?
Brad Roberts
May 7 2003, 01:59 PM
911's use drums for parking brakes Jon. They fit inside the 911 rear rotor.
He adapted them for use on a 914..
B
jonwatts
May 7 2003, 02:01 PM
Ah, I did not know that, and I wasn't able to tell from the 1 time I've driven a 911.
What do Nein Farty Fars use, same thing?
(practicing my Irish accent)
Brad Roberts
May 7 2003, 02:03 PM
Same thing.
Porsche (Thank God!) got rid of the hand brake in the caliper BS.
B
campbellcj
May 7 2003, 02:17 PM
I moved my front (914-4) calipers to the rear when I upgraded the fronts. Works well.
Not having the e-brake is only sketchy when you're parked on an incline. I carry little folding wheel-chocks in the car for use in that situation, just as an extra precaution.
I don't miss the damn 914-4 rear calipers and venting clearance crap one bit.
