QUOTE(unpolire @ Apr 5 2012, 02:59 PM)
QUOTE(haasman @ Apr 5 2012, 07:37 AM)
Speaking of ..... what is the exact color of the valence? Is it a satin black, a semi-satin?
Haasman
Also need this answer! Just picked up an OEM rear valence for a 1971 914-4 in primer. Have an OEM front as well, and need to know the correct finish!
You are very lucky to have found one! I looked for 3 years before I got mine (for my '72 four).
These were finished in 3 stages.
1. Primer.
2. Body Shutz, both sides.
3. Satin black paint, both sides.
The Shutz should be applied at low pressure (30-35 psi), and allowed to set for a day or so before painting. Don't buy the Shutz in a rattle can! Pressure is too high and does not produce the correct base. A gun is still available to make the proper finish (last time I checked, it was about $40), and you'll need a compressor. Your local FLAPS shoule be able to help, and it makes all the difference.
