QUOTE(glens67 @ Apr 13 2012, 12:19 PM)
Do I use 1/4", 5/16" or 3/8" Butyl
What is the thickness of the 2 rubber Support strips?
The Butyl tape that I removed was compressed To 3/16" and squished to just over 5/16", which leads me to thinking that it was 1/4".
Eric Shea's write up indicates a NAPA part # 4169 which is 3/8" wide.
Other how-tos indicated 3 sizes above.
Thanks
Glen
I used 3M 5/16 butyl tape. I remember the book (don't remember which one) was talking about 8mm that is about 5/16.
Regarding the rubber supports, they are there just to locate the window in the frame and absorb vibrations. The glass should not contact the lower metal lip of the frame or it will brake from vibrations.
I used the rubber blocks that came with the butyl tape. They were about 1/8-2/8. Just make sure the window is in place and doesn't touch the lower frame.
