Sorry to leave everyone in suspense. It is running!
Here was what happened. Since I wasn't getting fuel out of the injectors, but did have fuel pressure, I decided to start from the tank and work my way to the engine. I had installed all new 30r9 hose throughout the car. I did find a slight kink in the supply line under the tank, but not enough to cause a no start. After I remedied that I disconnected and reconnected every hose in the supply chain. When I got to the fuel rail I found that the inner Teflon (I think) lining of the 30r9 hose had folded over inside the hose when installed.
This would allow the rail to pressurize, but onl after prolonged cranking of the engine, but would not maintain the pressure due to the resistance of the blockage.
One that was repaired, I got in, crossed my fingers and turned her over. She fired on the 3rd short attempt!
I jumped out and held the throttle body to maintain 2500 rpm and got my break in cycle done. Hooked up all the rest of the bits, axles, heaters stuff, last weekend. Changed the oil and filter and drove her to work yesterday!
I love it! It's a 1911 with KB pistons and European Motorworks cylinders. L-jet FI w/ stock cam. 1.8L heads were reworked to 2L specs and intakes were ported. 1.7 rockers were modified for swivel foot adjusters. Rotating mass was balanced as well. She pulls smooh throughout the entire rpm range. I still need to tweak the AFM richen up the mixture. Just a tad lean.
Thanks for all the support here! Thanks to tim_nd for the PM's here and the bird site when we were attacked here. This site rocks!
On another note. If this site has EVER helped you out of a jam, please see the World fundraiser thread! Thanks Andy!!!
