TurboWalt
May 16 2012, 03:08 AM
Are there any rear brake upgrades for 5 lug that retain the parking brake? I've searched and can't find any difinitive answers.
sixnotfour
May 16 2012, 04:07 AM
914-6 calipers, bigger piston , bigger pads, same size as 911 rear calipers .
or use 911 rear caliper and add the 911 parking brake.
May 16 2012, 04:14 AM
I'm pretty sure Eric Shea/PMB has an alloy 914-6 rear caliper in the works.
wingnut86
May 16 2012, 05:05 AM
Check Chris's solution over at Tangerine Racing. Bring $$$, either way...
TravisNeff
May 16 2012, 07:59 AM
You can use a caliper spacer kit from Eric Shea and use vented rotors with the stock -4 calipers, or you can run the stock rear calipers with redrilled -4 rotors, or use 914-6 rotors (you may have to turn the outside diameter down a couple of mm, or clearance the caliper)
TurboWalt
May 16 2012, 09:46 AM
I'll look into those options. I do prefer to support forum members first when it comes to spending my $$$. I will add that my car has the Renegade big brake kit on it, but it isn't true 5 lug. From my pictures I'm positive I have no parking brake. I'll have to ask McMark to confirm this. When I inquired with him about what stub shaft and hubs I have is what started me heading down this particular road. I plan to use a 108mm CV with no adapter.
sixnotfour
May 16 2012, 01:21 PM
install 911 parking brakes is the most cost effective if you have the renegade brake package already.
Elliot Cannon
May 16 2012, 03:00 PM
Parking break? That's easy. Leave it in first gear.
Qarl
May 16 2012, 04:01 PM
QUOTE(Elliot Cannon @ May 16 2012, 05:00 PM)
My dilemma is that I started this Frigging project 8 years ago (BEFORE the 911 e-brake solution was fully sorted out).
I have these beautiful powder coated, reinforced, trailing arms with everything ready to bolt to the chassis.... and I really WOULD like to have an e-brake solution.
Unfortunately, I'd have to remove the hub (and destroy the bearing)... not terrible, but still not the desired solution.
And I'd have to drill and weld onto the beautifully powder coated arms.
Unless someone has figured out an alternative and true "bolt on" solution...
Aaron Cox
May 16 2012, 04:23 PM
^^^ I did what Karl wants to do.... Boxsters but with 911 hub/911 ebrake parts (still not finished LOL).
jimkelly
May 16 2012, 06:44 PM
what you got on front?
sure you need bigger brakes in rear?
would drilling rears for 5 studs and going 911 in front be sufficient?
jim
Andyrew
May 16 2012, 06:58 PM
Spacers in the stock calipers to accept the vented rear rotors... Thats what I use.
sixnotfour
May 16 2012, 07:14 PM
Martin Scheinder was working on a spot mechanical caliper ?? MSDS
ConeDodger
May 17 2012, 11:14 AM
QUOTE(mepstein @ May 16 2012, 02:14 AM)
This is a project being worked on by 914Rubber.Com and PMB. Pair this with the alloy front caliper and you have achieved 914 perfection. I have the PMB alloy fronts and I am anxiously awaiting the completion of the rear project...
I think you can just spy these beauties in this picture...
edwin
May 18 2012, 01:08 AM
QUOTE(ConeDodger @ May 18 2012, 03:14 AM)
Cross dirilled rotors and a phillips head screwdriver? Seems simple enough
ClayPerrine
May 18 2012, 10:56 AM
QUOTE(sixnotfour @ May 16 2012, 08:14 PM)
It was tried here in Dallas by Wes Hildreth on Mike Floyd's 914. We found that setting the park brake when the rotor was hot would mandate the removal of the wheel and a very large hammer to get the park brake to release.
Not a good solution.
sixnotfour
May 18 2012, 11:55 AM
I guess thats why we havent heard much ??
Qarl
May 18 2012, 12:33 PM
I would be interested in alloy front/rears if the rears could also be alloy and have the e-brake provision.
rfuerst911sc
May 18 2012, 03:06 PM
I added 911 brakes on all four corners to my GT clone. I kept the 911 e-brake setup it works fine. Just had to get extended e-brake cables and I welded a stud to the swing arm. On that stud I installed a small pulley. The e-brake cable runs around the pulley and into the e-brake actuator. Very simple and works great.
Dinobx
Jul 10 2012, 05:11 PM
At first I went with early 911 rotors and a Ferrari 308 rear caliper. Needed spacers for that solution, but the wonderful thing is the Ferrari 308 calipers had a built in parking brake with cable hookup. I decided after seeing the 911 ebrake solution, to go that route with Boxster rear calipers on early 911 rotors.
Don't know if that helps.
