cliffordbf
May 18 2012, 10:30 AM
One of my roommates has a mild obsession with LED's and has been trying to convince me to swap out all possible lights in the 914 with LED's.
Has anyone done a full on LED conversion on every single light, gauges included?
Does swapping to LED's require major work?
Also, does anyone have any experience with HID's in the Hi/Lows and Fogs?
Mike Bellis
May 18 2012, 01:41 PM
You can burn out the flasher relay with LED's. Some flashers will work fine. The difference is the lamp internal resistance. If you add a 4 ohm resistor to the lamp input, you will trick the flasher into thinking a standard buld is connected.
The big problem with HID's is the lens required to prevent blinding oncomming traffic. You need a parobolic lens with upper light diverter. This keeps the oncomming traffic (like the police) from being effected by the light. H4 halogen conversions should not be used on a 7" round lens.
matthepcat
May 18 2012, 04:37 PM
I run LED gauges converted by AL in the members section. Night and day difference in visibility, and much better upgrade than just swapping out the gauge bulbs to LED units. His thread is here:
http://www.914world.com/bbs2/index.php?showtopic=100721I also run LED fog-lights from JW Speaker that have hi/low function.
http://www.jwspeaker.com/My thread here:
http://www.914world.com/bbs2/index.php?sho...148405&st=0They work well as headlights, but are not as bright as HID headlights that I had previously.
Try going to
http://www.superbrightleds.com/You can get LED replacement lights, resistors and LED ready blinkers.
Matt
VaccaRabite
May 18 2012, 08:56 PM
I am using LEDs in my gauge cluster. WAY more visible at night, but not blinding. the stock bulbs were so dim I could barely read them. The ones I got (from Mikey914, I think) were direct plug in bulbs.
cliffordbf
May 18 2012, 10:59 PM
QUOTE(Vacca Rabite @ May 18 2012, 09:56 PM)
That is my issue with the gauge cluster...I hate not being able to read gauges at night.
Mikey914
May 19 2012, 12:00 AM
Yes I do have the LEDs for the dash, you do NOT want to replace gen light as it is actually part of the charging system. The bulbs run $1.95 each. I have replacement bulbs for the side markers, front and rear turn signals, as well as the running light and side markers. I'm converting my car to clear lenses so LEDs are a must. It's bck from paint but I have to go through and figure out where all the wires go. Just haven't had time.
TheCabinetmaker
May 19 2012, 05:28 AM
I have mikey's leds in my dash. They are better. Your welcome to check them out.
cliffordbf
May 19 2012, 10:29 PM
QUOTE(matthepcat @ May 18 2012, 05:37 PM)
Try going to
Matt
I checked out JWSpeaker and they don't seem to have prices on anything. How do I check prices or order???
Curt, I would like to check out your gauge cluster to see the LED bulbs
yellowporky
May 19 2012, 11:25 PM
call Jw speaker and they will direct you to a retailer near you.
matthepcat
May 20 2012, 09:43 AM
I got my JW Speaker LED lights here:
http://www.tlg-auto.com/default.asp?m=0If you can't find the model you want on their website, just email their customer support. The guy that runs it was awesome.
