Hello World,
I am finally in a position as soon as the Rotisserie is ready to throw this thing on and start gaining some momentum. I have found both sides replacement panels and have them. I have some photo's of the carnage and am seeking opinions.
My heap has alot of rust along the center tunnel which I do not think I have seen in many other cars but am probably wrong.
This car also has had several areas on the passenger side where they welded in angled steel and it pull the floor up actually turning the cross brace.
Please give your opinions......... one of the worst areas is behind the pedals which has some big rust damage, my replacement piece does not go that far. Are there other pieces available that reach all the way up there?
I also have an Engman kit that will be welded into the inside, what should the timing be on putting that in?
Set and fix floor pans first then put Engman kit in?
The car will also have braces mounted from bottom door hinge to door and from top door hinge to safety belt bolt hole on the side of the roll bar.
Thank you for your opinions and advice in advance.
Vysoc
