ezbngreen914
May 30 2012, 10:14 AM
I’m looking for suggestions and ideas for good items to keep in my 914, Sort of the ultimate supplement to the Factory Tool kit. This list could include anything from glass cleaning wipes to a spare jack that won’t cause spikes in blood pressure, spare fuses, extra cables? Etc. Someone one may have already put a list like this together or a similar topic may already exist on this site. I searched but didn’t find anything like it. If I missed it please point me in the right direction. As always I look forward to the “Worlds” unlimited knowledge. Just wandering what has proved useful to you.
Andyrew
May 30 2012, 10:53 AM
Axles, throttle and clutch cable, bolts, water, oil, wire, fuses, wd40, duct tape, tools to change all mentioned. On long trips I also carry a full tool kit.
Elliot Cannon
May 30 2012, 11:04 AM
QUOTE(Andyrew @ May 30 2012, 09:53 AM)
Plus jack and at least one jack stand. Blue tarp to work under car if parked in the dirt so you don't get your "T" shirt dirty. Emergency flares and of course cell phone and AAA membership.
flipb
May 30 2012, 11:42 AM
The #1 item I keep in the car is zip ties of assorted sizes. Also, glass wipes since my windshield washer isn't functional.
Although I did so in my own driveway (not a roadside), I once completed my throttle linkage with zip ties to last the ~5 mile drive to the mechanic.
ezbngreen914
May 30 2012, 03:01 PM
Some good ideas. I'll post a compiled list with everything I come up with and everyones suggestions at the end for what its worth. I wonder if I can fill up both trunks.
mrbubblehead
May 30 2012, 06:02 PM
i started a thread similar to this....lots of good info.
http://www.914world.com/bbs2/index.php?act...=2&t=175882
Woody
May 30 2012, 06:10 PM
I carry fuses and the associated tools to change em out.
seanery
May 30 2012, 07:35 PM
I second the throttle and clutch cables, you may not need them, but one of your buddies may!
Lennies914
May 30 2012, 07:52 PM
If you're running the stock ignition, points, condenser, cap, and rotor.
type47
May 30 2012, 08:07 PM
CV bolt triple square, tarp to lie on or shelter from rain,
struckn
May 30 2012, 08:18 PM
If you don't want to mess with a spare tire or need the trunk space carry a small 12V air pump and a Plug Kit with the glue, plugs and the insert tool. Fix flats with wheel still on car jacked up.
benalishhero
May 30 2012, 08:26 PM
I carry a fairly complete tool box, test light, jumper wire, points and condenser, spare relays, V/C gaskets, Jack. Um, that's about it....
r_towle
May 30 2012, 08:40 PM
Credit card and a cell phone
Always carry a coat hanger and a roll of electrical tape.
Rich
JimN73
May 30 2012, 08:43 PM
A jack, credit card, AAA card, phone. I expect it to work
bigkensteele
May 30 2012, 09:38 PM
All of the above, plus fan belt, clutch and accel. cables, fuel pump, duct tape, electrical tape, JB Weld, Bible, Torah, Koran, Buddha statue, Weje board, condoms and a spatula. Lots of lubricants, and a pouch full of Pesos, Euros, and Yen. When I go on long trips, I also include a AAA card, Hustlers and a flashlight.
speed metal army
May 30 2012, 09:47 PM
Fuses,BCAA card(AAA),Phillips head driver,used to carry one green top too(bye,bye!
ezbngreen914
May 30 2012, 10:11 PM
QUOTE(bigkensteele @ May 30 2012, 09:38 PM)
haha, I was wandering how long it would take for someone to go that way with it
Cap'n Krusty
May 30 2012, 10:51 PM
QUOTE(Woody @ May 30 2012, 05:10 PM)
"Associated tools to change em out"? What, like a few spare fingers?
The Cap'n
speed metal army
May 30 2012, 11:00 PM
QUOTE(Cap'n Krusty @ May 30 2012, 09:51 PM)
The Cap'n
Trains Planes and Automobiles.
http://www.imdb.com/title/tt0093748/quotes?qt=qt0267387
reharvey
May 31 2012, 04:32 AM
I have a tool box with just about everything that will fit in it. Fuel hose, injectors, MPS. fuel pump, cables, relays, fuses, tire repair kit, and all the tools to repair everything. Ray
rwilner
May 31 2012, 05:53 AM
surprised no one has mentioned hex sockets / allen keys -- you'll need those to remove the pedal board (5mm IIRC) or install a backed-out cone screw (4mm).
mrbubblehead
May 31 2012, 11:52 AM
QUOTE(rwilner @ May 31 2012, 04:53 AM)
i made my own cone screws with hex head bolts, drilled and saftey wired. no more of those dang cone screws
Woody
May 31 2012, 12:33 PM
QUOTE(Cap'n Krusty @ May 30 2012, 11:51 PM)
The Cap'n
Yeah so??
larss
Jun 1 2012, 04:27 AM
On longer trips I have quite a few tools and spare parts in the trunk, some of them are:
-Socket set 100pcs WITH socket for CV joint
-Multimeter
-Jackstand
-Gloves
-Carpet piece to lay down on
-Bolts, nuts, washers
-Terminals male/female
-Tie raps
-Tape
-Fuel hose
-Fuel hose clamps
-Breaker points
-Condensator
-Ignition coil
-Spark plug
-Alternator belt
-Alternator relay
-Injection valve
-ECU
-Fuel pump
-MPS
-Resistor (potentiometer) that can replace any temp sensor
-CV Joint
-Engine oil
-Starter cables
-Nippers, knife
-Polygrip tonge
Still there is room in the front trunk to take some additional luggage!
/Lars S
type47
Jun 1 2012, 06:19 AM
QUOTE(rwilner @ May 31 2012, 03:53 AM)
... and rear caliper adjusters...
rhodyguy
Jun 3 2012, 07:31 AM
for a long trip, a known to be good bulb for the generator warning light and at least one known to be good round relay.
CrashDown
Jun 3 2012, 09:49 PM
Flathead screwdriver, fire extinguisher, extra oil, generator blub, fuses. And latest edition of Playboy + 2-4hrs of porn loaded on my Nook Tablet. Ya know, incease I have to wait for the Tow Truck driver.
