r3dplanet
Jun 3 2012, 12:16 AM
If it it were possible to strangle myself I would have done it.
Over the past couple of months I've been trying to put my car back together. It came to me a long-term project but its slowly turning into something great.
Over the past week I've been driving it around and its really getting close now.
Except for the part where it's merciless to shift. Specifically, its a little hard to shift into just about any gear (enough to create a blister after one day of around town driving). But the main problem is that I can't get it to shift into first gear unless I nudge the car in another gear prior. For example, coming to a stop in second and shifting into first when the car has almost zero speed. Sometimes at a stop light I can shift into reverse or second and then into first, but this only works 50% of the time. Plus, I'm nervous as hell about keeping my foot on the clutch at red lights because I imagine the clutch cable snapping right then and there.
This is what I've done in the Great Do-Over of The Past Year as far as related work goes:
(1) A Dr. Evil transmission rebuild clinic + bonus ring gear reversal after the fact.
(2) A full Jwest Engineering linkage replacement including the linkage at shift console along with new bushings, u-joints, and what-not. All of this seems very smooth to me.
(3) a Rennshift sport shifter
(4) new engine mounts
(5) new transmission mounts from Wevo
(6) new clutch cable
(7) proper clutch adjust. Free play at the pedal a bit over an inch before it begins to engage.
The clutch tube seems intact. When the girlfriend pushes the clutch pedal the tube doesn't move. It's a little crappy looking at the body but it certainly seems to be intact.
I'm not sure if its the clutch itself. I doesn't slip out of gear and it pulls really well once in gear. No scorched potholder smell.
I've been all over the place with shifter adjustment. I'm pretty happy with the adjustment in that I can adjust it too far forward or aft, and it seems to be happy where it is. Reverse and fifth are the easiest gears to get in to. Apologies for ending the previous sentence with a preposition.
One other thing, the hotter the car and the day become, the harder it is to shift into any particular gear. Fourth gear becomes the hardest after first.
I've searched around in the forums but it seems like I've already done what I'm supposed to do in comparing my case to others. Maybe my car demands further sacrifice of some sort.
I'm all f-ing ears if anyone has some solid ideas for me. The car is staying put until I can crack this.
Thanks,
Marcus
underthetire
Jun 3 2012, 12:27 AM
Honestly, it sure sounds like your clutch cable is too loose. I'm no expert, but it helped a bunch on my car.
r3dplanet
Jun 3 2012, 08:15 AM
Too loose? Unless I'm unsure what you mean, I don't think that the clutch cable will adjust much further out. The clutch already engages pretty rapidly from the top of the pedal.
But you're right in that it feels like if I had more to pull it would be easier to shift. I just don't think there's any left to tighten.
How was your situation?
QUOTE(underthetire @ Jun 2 2012, 11:27 PM)
rwilner
Jun 3 2012, 08:45 AM
When you rebuilt the trans, did you use the 2nd-5th dog gear on first?
rwilner
Jun 3 2012, 08:49 AM
also, what trans fluid did you put in the box? if you still have the bottles, post a pic of the label.
rhodyguy
Jun 3 2012, 08:50 AM
have you cleaned the underside of the shifter? the springs get loaded with crap and will restrict the action of the Reverse Lock Out Plate. inspect the shift lever for excessive wear at the the RLOP contact point. check out the RLOP too. the edge that presses against the lever should be nice and straight with 0 signs of a wear curve.
ensure you have the cable clevis @ the pedal connection set to the correct distance. illustrated on pgs 70/71 section 5 of your haynes.
k
crash914
Jun 3 2012, 08:56 AM
cable could be wrapped around fuel lines...
McMark
Jun 3 2012, 09:04 AM
I've seen shift linkages that hit the engine mount bar and caused trouble shifting into certain gears. Check the basics first, then look deeper if you don't find the problem.
edwin
Jun 3 2012, 09:23 AM
Can you select first with the engine off?
Good way to check if the clutch is tight enough is to put in first and hold clutch in while cranking. If it is much slower to crank over than if it were in neutral with no clutch then you probably have the cable too loose.
I had trouble with selecting first and reverse was sometimes a bit clunky and it turned out to be the clutch tube wandering inside the tunnel as well as the firewall. Pain to fix but great result.
Cheers
Edwin
Cap'n Krusty
Jun 3 2012, 10:23 AM
QUOTE(crash914 @ Jun 3 2012, 07:56 AM)
Not likely, they're 3" apart.
The Cap'n
Richard Casto
Jun 3 2012, 02:35 PM
About to go mow the grass, so this is a quick reply...
1. I think everyone is asking about clutch disengagement as you are reporting problems in all gears. One cause of that is power still going through the transmission as you try to shift.
2. It would be good to get a list of what was done at the transmission clinic. I also would be curious to hear regarding the 1st gear synchro hub (rebuilt using a used 2nd-5th part?)
3. As Rich mentions above. What oil are you using. Particularly "slick" lubricants result in shifting issues. Porsche synchro design requires some friction to work. This is one reason that synthetics are NOT recommended regardless of those who say they use synthetics with no problems.
4. It may be difficult to say unless you have been able to compare to another 914 transmission, but what level of effort is required if you shift it manually through the gears directly at the shift console?
Richard
Dr Evil
Jun 3 2012, 02:40 PM
Does it grind going into reverse? If yes, the cable is too loose.
If no, I still think you need to check this. You likely need to put a spacer on the threaded end so you can tighten further. It is often that cables have not enough thread to tighten.
I have a whole article with graphics on how to trouble shoot this, but the link in my sig is no longer working. PM me your email and I will send it to you.
Dr Evil
Jun 3 2012, 03:29 PM
I have just discovered that I can load the PDF here.
r3dplanet
Jun 3 2012, 04:09 PM
All -
I'm stoked about the fabulous responses. Thanks a million.
Here are some answers to your great questions:
1. Reverse is easy to get into. It does not grind at all. In fact, its the easiest gear of all.
2. I double checked to make sure that the clutch cable and the throttle cable are not binding.
3. The oil I'm using is Castrol 80-90W GL-5, exactly what is says in the manual and right in line with what Dr. Evil suggests in terms of straight up dino oil instead of synthetic. I added it just a couple of weeks ago.
4. As for the 2nd and 5th cogs, I honestly can't remember. It was over a year ago in Tacoma and I had a steep fever during the session. What I do remember is that the Dr. asked why I even brought it in to rebuild because it looked really good inside. We changed one part for the hell of it.
5. Edwin - with the first gear selected and my foot on the clutch pedal fully depressed, the starter sounds just like it always does - zippy and happy.
6. General note: with the car in the air, its much easier to shift into the gears.
Here are some photos of what the clutch position looks like at rest and then fully depressed:
(I promise the car is cleaner than this)
This is the clutch at free play:
Click to view attachment And this is the clutch fully depressed:
Click to view attachmentI've also made another discovery:
At the shift console, I've noted that when I have reverse, second, or fourth gear selected the T-joint where the rear shift bushing attaches smacks right into the bracket. Like it wants to go another few mm. Even so, reverse, 2nd, and 4th gear seem solid once selected. Seen in this photo:
Click to view attachment The converse is that when first, third and fifth are selected there's a 1/4" gap when fully engaged:
Click to view attachmentI'm going back out right now to disconnect the linkage and see how easy it is to select gears right at the console. WIll report back shortly.
-marcus
r3dplanet
Jun 3 2012, 04:10 PM
Super awesome. But I can't download it. It keeps failing at different points in transit. I'll pm you with my real e-mail address.
QUOTE(Dr Evil @ Jun 3 2012, 02:29 PM)
Dr Evil
Jun 3 2012, 06:04 PM
Sent to you.
With what you describe, the non-stock shift setup you have there is causing you issues as it is not aligned correctly. If you could move the shift point 1/8" all your problems would go away as both sides would engage at the stops rather than hitting the stop on one side (R/2/4) and leaving a gap on the other (1/3/5). Since this is non-stock, it is a bit hard for me to be exact on how to do this without having hands on, but if you get the concept, you can fix this.
Are your roll pins in your shifter console rod (the one that goes into the case) tight with no play?
The only idea I have to fix this is to move the stops back about 1/8".
r3dplanet
Jun 3 2012, 06:37 PM
I see what you're thinking. The good news is the roll pin seems quite secure.
I took the day to sort pull everything apart and put it back together. The shifting works well enough at the console without the linkage connected. I took the shifter apart, cleaned it, re-lubed it, and put it back together.
After a do-over today it still shifts exactly the same except for the part where 4th is easier to get into because of the stupid seat belt bolt. I've examined that before but it still bound up a little. Added a washer, and no more binding in 4th
That part that I'm confused by is that if the bracket were keeping 1/3/5 from fully engaging, one would think that this side (the forward side) would be where there's a lack of free space. But it has a good 1/4". It makes more sense for r/2/4 to not fully engage because that's where there's no gap. Unless not having enough free spaced on the aft (1/3/5) side of the bracket is keeping me from getting a perfectly centered adjustment.
QUOTE(Dr Evil @ Jun 3 2012, 05:04 PM)
Sent to you.
rwilner
Jun 3 2012, 06:52 PM
Dumb question as I am sure you thought of this, but are the set screw stops on your rennshifter backed off fully?
If it were me troubleshooting, I'd start eliminating things. If you still have your stock shifter, pop it back in. If the gear engagement feels the same then it's likely the linkage or the clutch since you said the gears engage easily at the box.
r3dplanet
Jun 3 2012, 06:55 PM
Good thinking. The stop screws are all backed off. But I'll go see if I can find the stock shifter and see what happens.
QUOTE(rwilner @ Jun 3 2012, 05:52 PM)
r3dplanet
Jun 3 2012, 08:14 PM
Okay. I popped the original shifter back into place. It was certainly much easier and I think it's because it has a bit more leverage than the Rennshifter.
Notes:
With the stock shifter in place, its still hard to get into first, but not as hard. When shifting into first there's a bit of free travel and then a tight, bound up resistance and if it can get past that then it will slip all the way into first. Normally you can shift up until it gets hard but it never makes it past that hump. Does that make sense?
I adjusted the clutch further in but I'm afraid to adjust it any further. It already feels pretty tight now. Can some explain or post where the shifter lever on the gearbox ought to be when its fully engaged?
Otherwise, I'm noticing very minor resistance in the other gears also. Like there's a little bit of tightness before it drops into gear fully. Its far less pronounced with the stock shifter but its still there. I think that its first gear where you really notice. Now I think that it might be a system-wide issue instead of just first gear.
Clutch? Is there some way to measure or know without dropping the gearbox?
I don't think that the Rennshifter is the problem. Instead, I'm coming to the idea that the Rennshifter simply amplifies the issues because of trouble elsewhere. So I think the Rennshifter is alright. While its easier to get into gear, its clear that its just a leverage issue. The stock shifter is quite vague. But hey, I was able to zip around my neighborhood and really enjoy the car for perhaps the first time. In 3-4 years, I might have run through one tank of gas.
-marcus
r_towle
Jun 3 2012, 08:15 PM
Its your shifter console on the transmission.
There is not enough movement to get to first gear.
Rich
JWest
Jun 3 2012, 08:19 PM
Quote form the instructions that came with the kit:
Check that the shift cup does not hit the support when fully forward or back. If it does, adjust the position of the support or grind some material off of the shift cup at the point of contact. Very slight contact at full engagement is allowed, there does not have to be actual clearance. Too much interference will result in a bent support, though.
r3dplanet
Jun 3 2012, 08:37 PM
Quote from earlier in this thread:
When I installed the bracket there seemed to be good clearance.
JWest
Jun 3 2012, 08:57 PM
QUOTE(r3dplanet @ Jun 3 2012, 09:37 PM)
Yes, but if that tight side is hitting now and bent the bracket, then it will bind up the linkage.
Why is there a washer under the bolt holding the shift cup onto the linkage? Either that washer is loose and floating (no harm but not needed) or the bolt is not tight against the linkage and will slip.
With Porsche servo synchros it is rarely posible to select first gear whenever you want - some version of shifting while slowing or selecting a different gear prior is nearly standard.
r3dplanet
Jun 3 2012, 09:00 PM
Thanks for getting back.
Tomorrow I'll pull out the bracket and elongate the mounting holes or grind the shift cup and make sure that both sides are square. When I re-mount it I'll make sure that there's good clearance on both sides.
The washer is there simply because I'm used to putting washers in between parts and fasteners. Its on there really tight and there's no slop, but if you think its better without it I'll pull it out.
Thanks for your help.
QUOTE(JWest @ Jun 3 2012, 07:57 PM)
karnak
Jun 3 2012, 09:56 PM
ya' know, reading this reminds me of what i just went thru. i have a 3.0 SC and a 915 trans (in a '75 914). after a new clutch went in, the darn thing would not go into any gear. i discovered that the clutch disk was too thick. if you have any pictures of the pressure plate fingers before you installed the transmission. it would be good to look at them. if they are pointing outward toward the rear bumper where the throwout bearing contacts and not sitting flat (mostly) then you will have to pull out the trans and clutch to redo it.
my disc was a Raybestos brand. it was 0.025" (about half a mm) too thick. i spun the disk with my drill and with a belt sander, removed some material from both sides and put it back in. the fingers lay much flatter. it was a long day but i can select any gear now.
good luck! i hope this is not your issue, but thought it good to post my expierence
Gary
Dr Evil
Jun 4 2012, 04:54 AM
Once you get all the other stuff worked out (external adjustments), there are some caveats for first gear:
1) If you have a brand new synchro band, shifting is difficult without first going into another gear. This is because the new ones are very stiff. A great used one only takes one finger to shift into and it stays engaged. A new one takes considerably more muscle.
2) The transmission is not designed for one to slow down using 1st gear (translation: you are never to downshift into 1st gear for deceleration purposes). First is geared too low and downshifting into first is not recommended, and causes unnecessary and more rapid wear on the expensive 1st gear components.
r3dplanet
Jun 4 2012, 09:15 PM
Holy cats. Well, I think I found the problem and let me just state up front THAT IT IS MY OWN FAULT. Not that blame is important in troubleshooting. It's just that I feel like an asshat.
Somehow, and I don't know how, I tore the sh*t out of the console shifter shaft, and with it the sad-as-a-panda bronze bushing inside.
I can't for the life of me figure out how I did this. I installed everything when the gearbox was out of the car several months ago and it all bolted up as smooth as can be.
Two weeks ago I had to drop the gearbox because the diff was in backwards (remember the fever I had at the clinic?) when I installed it at the Tacoma clinic last year. I must have scraped the hell out of it getting it in or out of the car during the recent work. I'm good at self-blame, but this spooks me.
Anyway, here are the grizzly photos. I'm off to my machinist Gary tomorrow to see if he can bail me out of trouble.
Click to view attachment Click to view attachment
Dr Evil
Jun 4 2012, 09:46 PM
Hmmmm, I hope that fixes it
r3dplanet
Jun 4 2012, 09:51 PM
Yeah, between you and me I worry that even if I fix this it still won't shift into first. We'll find out soon.
QUOTE(Dr Evil @ Jun 4 2012, 08:46 PM)
r3dplanet
Jun 7 2012, 12:33 PM
Okay, so my machinist (also a 914 person) bailed me out of trouble with the damage. He smoothed out the damage to the shaft and replaced the bronze bushing. He also ground down the other side of the shift cup to make it uniform.
Pic:
Click to view attachmentBefore I reinstalled it I de-rerusted it and shot it with some caliper paint.
He found that even after doing this there still might be a clearance issue so he put the shaft into his lathe and removed about 3/16" of material from what used to be under the shift cup. Here's a photo, but it only shows what's missing. He just removed enough material to lengthen the shorter diameter of the shaft a little further.
Click to view attachmentI put it all back together last night and took it for a spin. It's now perfectly smooth in all gears .. except first. First is generally a little easier to panic shift into when there's a large delivery truck honking behind me. I would say that there is perhaps a 15% increase in first shifting success from a dead stop. So while there's some serendipity in finding the shifter damage, I'm really back where I started except that I know its not the shifter, the linkage, or the console. That's progress of a sort.
I think I'm starting the eyeball the first gear itself inside the box. Last night when I was under the car monkeying with the shifter I thought that maybe there was a little more resistance in manually selecting first gear. Or it could be my imagination.
In the meantime I'm trying to work on my shifting technique (2nd into first, slight 2nd into first, reverse into first). I realize that the 901 is a touch wonky with first gear anyway, but my previous two 914s never had so much trouble.
What's next on the diagnosis list? Checking out the actual gear? How do I do that?
Thanks everyone. I really, really appreciate the help I get here.
-marcus
Dr Evil
Jun 7 2012, 03:59 PM
Man, I hate it when guys use non stock shifter doodads as it kind of mucks up symptoms and may cause issues when they are boogered up. I would say that you can look at first, but I can not be sure that is the next step as I am unfamiliar with your shifter setup.
Shifting or not shifting at the box by hand is a very poor diagnostic and doesnt tell you much unless the shifter does not move at all. Gears are sometimes hard and sometimes not, and it usually means nothing.
r3dplanet
Jun 7 2012, 11:25 PM
Well, that's fair. I don't really know the next step either so I'm just leaving it for now.
bugsy0
Jun 7 2012, 11:46 PM
Has anybody mentioned the ball-stud in the bell housing, on which the clutch release fork pivots? The plastic cup wears out, causing the release fork geometry to go out. This in turn causes symptoms such as running out of adjustment room on the clutch cable.
rwilner
Jun 8 2012, 09:38 AM
In *my* transmission....(disclaimer to all below)
I had some binding shifting into first when shifting into it at a dead stop. During the rebuild a stock 2nd thru 5th gear dog gear was used on first -- a very common practice used by many to save some $.
Fast forward 2k miles and the problem improved due to breaking in of the brand new stiff syncho ring (I presume), but it was still present. I then had the dog gear modified to use the normal first gear parts (special claw thrust block and only 1 brake band). Now I can get into first 100% of the time at a dead stop.
Again -- this is my car with its own insanities and YMMV but this could be contributing to your "shifting into first" woes.
Good luck!
Rich
r3dplanet
Jun 8 2012, 09:45 AM
I've read events just like this one enough times to suspect (or at least have a desire to double-check) that I may have a similar issue. But frankly I couldn't differentiate a dog gear from thrust block, let alone know how to inspect, replace, or modify them.
As for the plastic shift cup on the release fork, I don't remember what its condition is. Or if its even there. That's actually pretty stupid of me because I just had the gearbox out a few weeks ago. Still, clutch throw doesn't seem to be the issue.
QUOTE(rwilner @ Jun 8 2012, 08:38 AM)
Good luck!
Rich
rwilner
Jun 8 2012, 09:53 AM
QUOTE(r3dplanet @ Jun 8 2012, 11:45 AM)
FYI -- first gear (and reverse) can be checked with the transmission in the car. You need to pull off your muffler and the transmission tail cone to get to the 1st gear stuff.
r3dplanet
Jun 8 2012, 10:25 AM
Yes, thank you. I know this part at least. Getting the tail cone off and looking around is within my ability and I'm not spooked by that part of the chain. But I'm ashamed to say that even after the rebuild clinic and repeated DVD viewing I don't feel any more competent to know what to look for than do-it-yourself-surgery on my own organs. Just feel stupid. If I had a little more experience I know it would easy enough to just see what I have and verify.
Here's the graph:
Step 1: Drain gearbox, remove muffler, support gearbox, and remove rear mount bolts. Pull tail cone.
Step 2: ?
Step 3: Profit.
QUOTE(rwilner @ Jun 8 2012, 08:53 AM)
ChrisFoley
Jun 8 2012, 10:35 AM
Its impossible to tell if a 2nd gear synchro hub is installed on first gear without removing the gear and then removing the snap ring off the synchro...
unless the rebuilder noted it on the invoice/set-up sheet that is.
Dr Evil
Jun 8 2012, 05:18 PM
Bull shit, you can see if there is one or two notches on the inner metal lip without removing the snap ring. One notch = 2-5, 2 notches = 1st.
Also, the 2-5 bands and teeth would not cause this. New bands will DEFINITELY do this. The new bands are stupidly stiff to the point that I avoid using them at all cost.
r3dplanet
Jun 8 2012, 05:51 PM
Okay. Everyone, I didn't mean this topic to get heated. Let's just retire this post for the time being. I'm now in the middle of a front brake do-over. Once that's done, I'll drive the car like crazy for a couple of months and see if the situation improves based on the idea that the band wears a little.
Assuming that is, that the sun ever comes out. Its still raining here in the middle of Juneuary and I can't drive the car if I wanted to as I have a no-rain policy for the car.
All good.
Thanks to everyone for their super insight. I love this site.
-marcus
ChrisFoley
Jun 8 2012, 10:08 PM
QUOTE(Dr Evil @ Jun 8 2012, 06:18 PM)
...you can see if there is one or two notches on the inner metal lip without removing the snap ring. One notch = 2-5, 2 notches = 1st.
You are correct sir!
the cutouts are visible from the id
