QUOTE(Tom @ Jun 17 2012, 11:44 AM)
Jim,
While that would work electrically, the high currrent may be too much for the power relay. ? Not sure of the current rating on these relays for the relay board. The relay provides the power to #1 of the 4 pin socket. According to Haynes, the pullin current for the starter solenoid is 35 amps, hold in is 11 amps. That was the reason I used a 50 amp relay for the bump/hot start setup on mine. The current to drive the relay I used is 135-150 miliamps. Also using this as a bump feature without a relay using low current will accelerate wear on the switch contacts due to the inductive spike. That is what the diodes are for on the one I made up. Usually, relay contacts are made from a different material that handles inductive spike better than switch contacts.
Tom
Thanks for the heads up, I see what you mean.
