Well I took the plunge and decided to install the louvered panel in my front trunk. This is going to allow the hot air to exit from my front oil cooler out of the trunk.
I have encountered several problems however. First, my welding skills are extremely rusty and are proving quite challenging.
Second, I cut the hole out a bit too large so that the gaps are a bit more than the expected .040 inches I had hoped for.
Here's a picture of the damage:
So here's my question. Should I simply start trying to tack the points I can easily tack and then fill in the big gaps with lots of welding wire? Or is there a better way to do this?
As usual, all advice is greatly appreciated in advance. Thanks.
