I am in the process of welding up the trouble areas in the engine bay in preparation for a 3.2 conversion. I removed the engine mount supports, and then the rusted longitudinal sections underneath, so the battery tray is currently in the scrap heap. I would like to cut out the suspension ears because they keep catching my back as I bend under, but will stop short of that . But it occurs to me that I need not necessarily want to replace the battery in the original place. My 911 for example carries its battery in the nose, neatly counter weighting the AC compressor that isn't currently there.
Also, a battery in the stock 914 location might be a bit in the way with the 3.2.
So, what is the preferred location? Stock? Or, moved.
BTW. Are there any other things that I am better off without such as the MPS bracket or the relay box holder? I am hoping to gain from your experiences.
Thanks.
