QUOTE(bandjoey @ Aug 9 2012, 06:18 PM)
Aircooledtechguy made a statement about timing advancce that makes me think...I've not checked the timing since the distributor is positioned just like I bought the motor.
Is there a way to static check the advance timing on the 009? How?
Unfortunately you do not have the ability to statically time your motor if you have one of the pointless ignition systems installed like Compufire, Pertronix, etc. The only way to do it is while running with a strobe.
You can estimate it though by just ensuring that the rotor tip is in about the correct position in relation to where the contact in the cap is. If, when you try and start it, it seems to fight the starter, that means the timing is too far advanced. So retard the distributor by turning it CLOCKWISE in it's bore.
In general, a motor will start with it's timing way to the advanced side, but not if it's equally off on the retard side. So it's best to guess too advanced and correct it once it's running.
Many-a-motor have been tuned to a hault by having the plug wires in the wrong order. I've seen folks spend days of frustration trying to start a motor and spend a lot of money changing good parts when with the plug wires are on in the wrong order. . . Just to re-cap: get the motor on TDC #1 (pull a valve cover and ensure BOTH valves are loose). Install that wire to #1. From there in a CLOCKWISE order #4, #3, #2. The cylinder numbers are conveniently stamped into the tin.
I've just seen this too many times to not mention it. . .
You'll get it!! You're on the precipice of greatness!!
