Aaron Cox
Oct 25 2004, 03:58 PM
letz hear the horror stories
MattR
Oct 25 2004, 04:02 PM
So far: my head stud. You know the story...
Well I have some pain in the ASS head stud thats just wierd. Its shorter then the rest of the studs and it just wouldnt come out. I had to buy a head stud puller that would work, but aaron's man hands finially got it out (i wonder what he does to work them out???). Now I need to find a new/used head stud so I can finially adjust my valves and start it up!
Jeroen
Apart from rust issues... <_<
I think the most irritating part to get out of the car (let alone put it back in) is the window venting system under the front cowl
SLITS
Oct 25 2004, 04:03 PM
Buying a wreck and making it run.
#1 - electrical
#2 - electrical
#3 - electrical
#4 - el.......................,
DNHunt
Oct 25 2004, 04:04 PM
Dealing with exhaust leaks. Hard to fix, hard to see, dirty.
Dave
ematulac
Oct 25 2004, 04:11 PM
QUOTE(SLITS @ Oct 25 2004, 03:03 PM)
#1 - electrical
#2 - electrical
#3 - electrical
I've ripped out the power windows, the power mirrors, the stereo system, and all the crappy wiring that was already in my 914 when I got it. Everything was great for about a month, then I went and short circuited something somewhere and I still can't find it.
brant
Oct 25 2004, 04:14 PM
-rust
-electrical
-hard to find FI issue...
drum roll.....
- those damn outboard cv joint bolts....
brant
Sammy
Replacing the rubber seal for the engine shelf with the engine still in place, replacing the master cylinder,
un-doing the DAPO's "custom" electrical work.
Joe Bob
Oct 25 2004, 04:15 PM
Anything that involves old tranny gear oil...god I hates dat smell.....
QUOTE(acox914 @ Oct 25 2004, 02:58 PM)
Worst task on a 914???
filling her up at the gas-pump ...
Andy
Aaron Cox
Oct 25 2004, 04:17 PM
gettin those damn turbo tie rod boots on the rod when its attached to rack,
i HATE valve adjusts
qa1142
Oct 25 2004, 04:18 PM
Thats an easy one
Mothballing for winter storage
TimT
Oct 25 2004, 04:29 PM
LOL ya dinosaur shit
That is the worst
MattR
Oct 25 2004, 04:37 PM
QUOTE(qa1142 @ Oct 25 2004, 02:18 PM)
Thats an easy one
Whats that?
bondo
Oct 25 2004, 04:41 PM
Poking at the rusty spots with a 914 rust dectector (screwdriver) and having it go right through.
scottb
Oct 25 2004, 04:46 PM
skline
Oct 25 2004, 04:48 PM
Least favorite would probably be replacing a rear quarter panel and getting it to fit right. Everything else has been easy, time consuming, but easy.
dinomium
Oct 25 2004, 04:49 PM
that one is WAY UP THERE! and cutting your knuckle on the retaining clip for the e brake cable right below it!
Clutch tube repairs are right up there too!
Aaron Cox
QUOTE(scottb @ Oct 25 2004, 03:46 PM)
that and the boot for the speedo cable thru the firewall
BPGREER
Oct 25 2004, 04:52 PM
putting the boot back on at the firewall for the side shift tranny. it is impossible. mine still hangs down, unattached to the firewall!!!!!!!
Just did that yesterday. I decided I would just leave it hanging, but of course I crawled back under the car and fidgetted until it went on. It is a pain in the ass. Valve adjustment is a pain, but not as bad as I thought it would be. Strange FI problems top my list so far.
dlo914
Oct 25 2004, 04:56 PM
Cons
1. Dizzy went bad = $100 + Core exchange
2. Tearing/Cleaning
out the interior and found all this gunk on the floor boards
3. New Carpeting = $100
3. Too many to list =
Pros
1. Found just about $7
worth of change underneath the driver seat
2. The roar of the engine and it's just a BLAST
3.
Driving a 914 = PRICELESS (not talking about the wallet)
watsonrx13
Oct 25 2004, 05:05 PM
Replacing the right rear suspension ear...
Dr Evil
Oct 25 2004, 05:35 PM
Moving it around to keep it from being poached by the vehicle abatement police
TheCabinetmaker
Oct 25 2004, 05:48 PM
Guy's, don't fight the shift rod front boot. A bit of light oil, and it'll slip right on.
URY914
Oct 25 2004, 06:04 PM
Replacing a master cylinder with the gas tank still in the car.
Those f%@&@^ brake hoses coming down from the top.
Trick is to instal the hoses in the m/c first then install the m/c.
Also the steering rack is a bitch to re-install.
Paul
nebreitling
Oct 25 2004, 06:06 PM
stripped exhaust studs
i f-ing HATE dealing with that...
JoeSharpOld
Bleyseng
Oct 25 2004, 06:09 PM
Geoff
Series9
Oct 25 2004, 06:15 PM
Removing fuel lines from the bottom of the tank.
Removing CV joints from the tranny flanges.
Rear bearings.
Supply lines to the top of the master cylinder.
nebreitling
Oct 25 2004, 06:19 PM
this thread is like one big 914club cathartsis!
siverson
Oct 25 2004, 07:01 PM
You guys already got most of the good ones. During reassembly of my -whole- 914, these were the things that I hope never to do again.
- reassembly of defroster vent/controls
- reassembly of headlight mechanism
- removing undercoating (anywhere)
- any sort of welding/grinding/heavy metal cutting (removing -4 motor mounts, installing GT stiffening kit, etc, etc)
I like electrical work... It's the one thing that to me seems simple to diagnose and makes sense - either it works or it doesn't.
-Steve
IronHillRestorations
Oct 25 2004, 07:17 PM
QUOTE(Jeroen @ Oct 25 2004, 02:02 PM)
I'll 2nd this one.
Allan
Oct 25 2004, 07:21 PM
QUOTE(914RS @ Oct 25 2004, 04:15 PM)
C'mon, it's not that hard.
Joseph Mills
Oct 25 2004, 07:34 PM
ppickerell
Oct 25 2004, 07:35 PM
Least favorite task on 914? Don't hate me for this because I wrenched on my cars for years.... but my worst is having to harass the shop that does my repairs
ppickerell
Oct 25 2004, 07:37 PM
Is it done yet, how much is it going to cost, $2000 for a LSD? (It was $5 a hit in my day)
Aaron Cox
Oct 25 2004, 07:42 PM
QUOTE(ppickerell @ Oct 25 2004, 06:37 PM)
hahahhahh
another evil task is suspension bushings.... tedious (grooving etc)
Joe Ricard
Oct 25 2004, 07:45 PM
Adjusting valves with all the heater ducting in place.
Chasing oil leaks
The whole process of getting to the defroster duct:
- drain gas
- pull tank
- pull duct hoses witout screwing them up
- pull fan housing and getting to the clip and cable retainer WITH OUT SCREWING THEM UP
- Figuring out how to fix the fucking thing
- getting it all back in place
All this is forgotten when it blows air in 3 speeds without rattling like it's going to go into orbit.
TheCabinetmaker
ahhh, suspension bushings. A truly unpleasant task!!!!
McMark
Oct 25 2004, 07:47 PM
Windshield Wiper Motor!!
Without breaking the rubber mount. Pain in the ass.
Aaron Cox
Oct 25 2004, 07:49 PM
QUOTE(markd@mac.com @ Oct 25 2004, 06:47 PM)
i second this!!!
PITA on steroids!
bob91403
Oct 25 2004, 08:07 PM
Repairing or replacing the NEXT damned thing. By the time I'm through, this car will be new! Was that a haiku? Huh, who knew?
Aaron Cox
Oct 25 2004, 08:10 PM
QUOTE(bob91403 @ Oct 25 2004, 07:07 PM)
nope
haiku's are 5,7,5
bob91403
Oct 25 2004, 08:19 PM
QUOTE(acox914 @ Oct 25 2004, 07:10 PM)
nope
haiku's are 5,7,5
Yeah, I knew. Three sentences, 5 syllables, 7 syllables, 5 syllables. Didn't expect anyone here to be able to SPELL haiku.
Matt Romanowski
Oct 25 2004, 08:25 PM
There are some really good ones here, but mine is taking out / putting in a centerconsole. I would do ANYTHING on a 914 before doing this.
Matt
boxstr
Oct 25 2004, 09:17 PM
Trying to remove the targa bar pad.
CCLININGASPAINTHEASS
MattR
Oct 25 2004, 09:23 PM
All this makes me not want to do anything... I still have to do: rust repair (hell hole), remove dash, replace master cylinder, and a bunch of other stuff thats listed.
tod914
Oct 25 2004, 09:39 PM
Oil cooler seals with the engine in
ThinAir
1) anything involving ru$t
2) poor electrical grounds
3) valve adjustment
jimtab
Oct 25 2004, 10:19 PM
