I have a wavy concrete garage floor.
Has anyone ever carefully measured and leveled the tub (independent of the floor) so that you know the chasis is straight, only to measure your fender arches from the floor and find what looks like a twist?
I'm feeling very paranoid because I've finished the structural repairs on the driver's side and am about to begin on the passenger's side. For curiosity, I took some measurements from the floor to the centers of the arches and here's what I found:
My measurements from the floor to the flanges on the rear suspension consoles are identical. At the front, the rear of the DS T-tube is 3/16" higher than the same measurement on the PS. I can shim that on the jack stand but I don't think that's going to bring the rear PS fender arch down or even out the fronts.
I'm trying to borrow an 8' spirit level from a friend so that I can level both sides of the car and make sure they are parallel.
***What are good index points for establishing "parallel"?
***And also, back to the original question: can the frame be true and the arches not be, presuming that there hasn't been previous crash damage that required replacement of a panel?
