QUOTE(hot_shoe914 @ Sep 16 2012, 12:24 AM)
Let's see the list, maybe we can help.
1- Needs front and rear shocks badly
2- Tie Rod assemblies need upgraded
3- Clean & Grease steering rack and replace right side boot
4- Battery hold down cable!!
5- Instrument cluster light
6- Oil leaks from valve cover gaskets and needs valve adjustment - BADLY
7- Oil leaks from push rod tubes and oil temp sending unit
8- Needs shifter bushings and current short shift creates no leverage
9- Blower switch is not working
10- All heater hoses and ventilation hoses are missing!
I have no idea what this stuff should cost to replace or repair depending on the situation. I know I will probably get banged on the parts since he needs to make his cut. But I can't exactly ask I guy to fix my car and bring him all the parts......lol.......That's kind of cold.
Here you go?
