jersey914
Sep 19 2012, 08:53 PM
I would be interested to hear how fast everybody's 914's are. Please include any information you can about your car. ie. Motor size, tranny, fuel setup, stock, track setup etc.
Pictures are welcome! I would especially love to hear from the admins and all you 914 aficionados.
r3dplanet
Sep 19 2012, 08:58 PM
I've clocked a 0-60 time around nine seconds. Beat that, suckers!
iamchappy
Sep 19 2012, 08:59 PM
Sometimes i think it's to fast......
Eric_Shea
Sep 19 2012, 09:10 PM
Where's Elf when you need him??
Maltese Falcon
Sep 19 2012, 09:13 PM
It's really not a fast car....more like a slow jet.
The last chp cruiser that I slowed down for, actually thanked me for stopping.
I think the Bell jet ranger following me was the deal breaker.
Marty
ezbngreen914
Sep 19 2012, 09:15 PM
About 69,900 MPH*...
*relative to the sun. Owners of cars on jack stands will be happy to know that in this case their cars are actually faster 50% of the time...
VaccaRabite
Sep 19 2012, 09:19 PM
I tend to drive slow.
I'm boring that way.
But I got my 2056 up to 95 according to my GPS. It felt like it had a lot left to give, but I did not want the ticket so I backed off and resumed my somewhat plodding pace.
Following Mike in his 3.2 6 superbus from York to Hershey late at night a few aprils back, he set the pace. At times it was quick, but my speedo lies and I did not have the GPS on for real speedo action.
Zach
pcar916
Sep 19 2012, 09:25 PM
Hmmm. Fast enough to get me out of trouble faster'n I got into it, not that I haven't made a mistake now and again. Power requires restraint, then intestinal fortitude to push it to the limit again. It's a process.
But after running a 3.6L engine, a 19lb flywheel/clutch package, and short gears for the last 12 years have showed me that, in no uncertain terms, I want more power. Oh yes.
Mike Bellis
Sep 19 2012, 09:31 PM
Too damn fast. Hard to control... ~400hp Turbo Rotary... Pulling it this weekend to install a 300hp Audi 1.8t...
timothy_nd28
Sep 19 2012, 09:33 PM
I got 100mph (GPS reading) a few weeks ago on the toll road. I still had plenty of go left on the accelerator pedal, however I was getting concerned with the high RPM's. If I remember correctly, it was pushing 5k.
1911 with Ljet
majkos
Sep 19 2012, 09:48 PM
well, there's this one time I manage to sneak a look at my GPS,
103, while travelin' with a bunch of teeners couple weeks back,
problem is, I'm the slow one
Sep 19 2012, 09:59 PM
I hit the rev limiter around 135mph. Stock 901. I would need custom gearing to go any faster than that.
0-60 is somewhere around 3.5 to 4 seconds, provided i can manage to keep the tires from spinning.
I could probably get to a reliable <3.5 seconds with custom gearing, wider tires and a limited slip.
Sleepin
Sep 19 2012, 10:18 PM
messix
Sep 19 2012, 10:25 PM
7500rpm in 4th gear in tony's v8 car when we smelled clutch [read my avatar]
100mph three abreast on a 2 lane freeway with 2 other teeners going to a mt baker run. 1.8 l-jet
MrLeeS
Sep 19 2012, 10:30 PM
I hit the rev limiter @ 139 according to TomTom. Gets there much faster than a f150 lightning and really pisses off the motor transport officer that pulled me over.
2366 turbo 10lbs boost.
Andyrew
Sep 19 2012, 11:05 PM
We'll I've maxed out 5th with 26" tires.... IIRC it was north of 140...
With the top off...
Drums66
Sep 19 2012, 11:33 PM
Jeffs9146
Sep 20 2012, 12:06 AM
I have a rev limiter that cuts out at 6k and before I got the timing set properly I slowed down at 108 with lots of pull left!
I am running a 3.0L FI with a stock 901 and now that I have it set up, and, once I get my sway bar on I can try again!
I am going to guess that when it is maxed out at 6k it will be at about 115-120mph but I don't think I want to go any faster than that so I will leave the rev limiter in! Red line is 7K and we all know that red line is just a line!!
speed metal army
Sep 20 2012, 12:16 AM
Faster than before!Im not sure how fast that is tho.I'll get back to ya.
messix
Sep 20 2012, 12:22 AM
QUOTE(Andyrew @ Sep 19 2012, 10:05 PM)
With the top off...
how did the car handle that fast with the top off... twitchy, floaty, planted?
DBCooper
Sep 20 2012, 07:04 AM
An official 13.006 quarter at 107mph on a hot summer afternoon. Subaru WRX engine and transmission with Quaife, on Falken Azenis. Put on slicks to get into the 12's as the afternoon cooled and immediately broke a CV joint.
Cap'n Krusty
Sep 20 2012, 07:58 AM
140 MPH with stock gearing requires the engine to be turning approximately 6400 RPM. 105 requires about 4800 RPM. Because of wind resistance and other factors, that speed just about uses up all the available HP on a flat road. Generally speaking, pretty much anything faster than that involves a lot more HP or a lot of hot air on the part of the driver.
The Cap'n
Andyrew
Sep 20 2012, 08:56 AM
QUOTE(messix @ Sep 19 2012, 11:22 PM)
With the top off...
Floaty on decel. But I had the then GF in the car and she didnt notice anything. I wouldnt do it again without a few tweeks in the back end to create stability.
Captn,
Your top speed assumes stock tire height. With a larger tire size that speed is increased.. A 25.85" tire at 5750rpm is 140mph... At 6500 its 159...
SLITS
Sep 20 2012, 09:00 AM
Fark ....
126 in my 2.0L 4 cyl by GPS
135 in my 2.7L 6 cyl .... which was plenty fast enough to be shot by the Utah State Patrol.
jimkelly
Sep 20 2012, 09:05 AM
most soccer moms can leave a stock engined 914 in the dust
Michael N
Sep 20 2012, 09:28 AM
Fast enough to have the air fold the driver's side mirror back against the car. I need to take it off and tighten it all up.
pt_700
Sep 20 2012, 09:34 AM
i'm suspecting the cars w/o tins (water cooled conversions) are more stable at speed.
there's a low pressure area behind the rear window. an open pathway between this and the bottom of the car (through the engine grille) allows air to be pulled from beneath the car?
i've had my stock 1.7 up to an indicated 100 (probably optimistic speedo).
what say the conversion guys about this theory? was your car more stable at speed w/o the tins?
'73-914kid
Sep 20 2012, 09:58 AM
124 mph with the top off in my 4. I hit the rev-limiter HARD and it wanted to keep pulling. Done with GPS on my way back home from school late one night. Didn't notice any instability on accel, but on decel it definetely felt like it was wanting to wander and get loose.
ballioint
Sep 20 2012, 10:16 AM
Mine is about to get faster....in about $10k from now....
Rockaria
Sep 20 2012, 10:41 AM
Well last time I was out I was passed by a school bus and a prefab home being towed!
balljoint
Sep 20 2012, 10:59 AM
Sorry.
matthepcat
Sep 20 2012, 11:01 AM
Never tried. Too worried about the CHP catching me and crushing my car for "street racing".
dwillouby
Sep 20 2012, 11:09 AM
Speedo maxed , Still pulling hard. Felt very light. Got scared and backed off.
425HP V8, Regeared 901
David
Thestigz06
Sep 20 2012, 11:15 AM
I was running an undersized wheel and tire setup but I got her up to 120 mph according to the speedo. How much that actually is, idk.
1.7 d-jet with 901 tranny and 195 50 15 tires
ballioint
Sep 20 2012, 11:22 AM
QUOTE(balljoint @ Sep 20 2012, 08:59 AM)
QUOTE(ballioint @ Sep 20 2012, 12:16 PM)
Jackass.
What?
JmuRiz
Sep 20 2012, 11:25 AM
Fast or quick? Mine currently goes 0-0 in 0seconds flat (since the motor is out of it
When I had my 2.0 with webers and a carb-friendly cam did an indicated 110mph flyby at the 2004 (?) ECC on Richmond's beltway.
Elliot Cannon
Sep 20 2012, 11:41 AM
I respectfully refuse to answer on the grounds of the 5th amendment.
ChrisFoley
Sep 20 2012, 12:01 PM
Max speed shown was on I-81 in Virginia, on my way to MUSR11.
Click to view attachmentShortly afterward I was stopped for going 81.
1.7L cammed & carbed.
mittelmotor
Sep 20 2012, 12:04 PM
I've had mine up to about 120 at night, headlights shaking violently. My car has the stock metal front valance, and it certainly felt light, but still stable at that speed. Sorta like a speedboat getting up on plane and lifting the nose!
I think an LE-style spoiler up front would help.
balljoint
Sep 20 2012, 12:35 PM
SUNAB914
Sep 20 2012, 12:47 PM
Looks fast, sounds fast, ain't real fast!
boogie_man
Sep 20 2012, 01:05 PM
I've gotten mine up to 7 mph as a rolling shell you bastardos............
euro911
Sep 20 2012, 01:11 PM
Got the 'BB' up to 100 on flat ground on the way back from the 2012 Rt-66; carb'd 2056 on 195/65x15 Michelins. Final jetting still isn't dialed in, so who knows
Pegged the 120mph speedo with the wife's '71 (going downhill) on the 2007 Rt-66 Run; 1.7L FI on 165HR15s ... with 2 people in the car
ballioint
Sep 20 2012, 01:22 PM
QUOTE(balljoint @ Sep 20 2012, 10:35 AM)
QUOTE(ballioint @ Sep 20 2012, 01:22 PM)
Jackass.
What?
I thought you were moving to another continent?
No, I am still incontinent.
balljoint
Sep 20 2012, 01:26 PM
ballioint
Sep 20 2012, 01:43 PM
You celebrate Christmas up there and hold internet conversations with yourselves?
BajaXJ92
Sep 20 2012, 01:52 PM
Jesus Herman Christ, will someone please hit Dave's reset button again, seems someone slipped some Xanax in his protein shake again.
balljoint
Sep 20 2012, 01:54 PM
QUOTE(BajaXJ92 @ Sep 20 2012, 03:52 PM)
It's not me. Look at the screen name, mine has a "j" in it.
BajaXJ92
Sep 20 2012, 01:56 PM
QUOTE(balljoint @ Sep 20 2012, 03:54 PM)
Look Dave, its not our fault that apparently there was some inbreeding somewhere along in your blood line and someone slipped in a little bit of American, so to speak.
jsayre914
Sep 20 2012, 02:02 PM
I just got a smart phone (my first one)
wich app is best for 0-60mph (free)
