Full Version: Improving 2.0 /4 stock cooling system
Mueller
Since my /4 will be under the influence of positive manifold pressure, i think keeping the motor cool will be a major concern.
Since I am on a tight budget (who is not these days) I cannot go to extremes with products like the 911 fan conversion or the dual electric fan setup. My dream setup is a horizontal fan, but for now I need to keep the stock 2.0 FI plenum and manifolds, besides, the bevel gears are loud and rob horsepower and the oil fill housing is in the way for a clean setup.
Has anyone changed the fan? or modified the stock fan for better flow? i know that some have removed a few fins but I thought that was not good for a motor that might have to idle for long periods of time like in traffic.
Can anything be done to the fan housing assembly to improve the airflow?
(baffles, diffusers, vortex generators???)
I know it would only cool the back of the motor, but I had thought about machining the back of the flywheel to create "fins" that could assist in suppling air to the motor...crazy? yea smile.gif
fuch toy
It wasn't REAL expensive, but I really had no choice.
My dual electric fan set up.......
$175 for the cowls, alternator stand and bottom pulley versus $350 new...thanks to Tim Hannum
$99 for the alternator...90 amp....woo hoo...(Summint Racing)
$235 for the dual fans and the thermostat (Racer's Supply)
less $150 I got for the 2.0 tin and 914 alternator....
$359.....plus 5 bucks for the rattle can to paint the shrouds..... 1200 cfm fan cooling versus the stock....
Bleyseng
Mike, install a front oil cooler. The fan set up is pretty well thought out with lots of CFM of airflow. It poops out after 5000 rpms so if you are going to a turbo an oil cooler for those hot summer days is the ticket.
Geoff
fuch toy
Just an addition....when I added the exta oil cooler up front to the 911/3.6....it does not have a cooler in the the motor like TypeIVs and earlier sixes.....the cooler, adapters and lines cost me over $500 bucks.....plus the air dam....
Mueller
I'd like to have piston squirters, but I'd have to split the case and send it off for that modification. I have an oil cooler already, just not installed yet (have to decide where to put it and if I will be running a water-to-air intercooler)
Back the fan:
Do both sides get equal flow? I know the right side has to deal with the oil cooler so some flow or pressure might get reduced due to that.
Even with modern electric fans being able to run for thousands of hours non-stop, I'd still like a mechanical solution for cooling, besides with my fuel injection and ignition, I'll have enough electrical gremlins to worry about...
fuch toy
The connect is pretty idjut proof....thermostat hooked into the positive lead, when temp is achieved, the circuit closes and actuates the permanently grounded fan(s). With the 90 amp Delco alt, you got gobs of juice compared to the 55amp stock unit. The temp sender mounts over the #3 cylinder head....
Temps are gonna be watched closely with the forced induction, so any increases would be shut down time anyways.....
GWN7
Wouldn't the addition of electric fans mounted under the engine hood/grill pushing air out from the engine compartment increase the air flow enough to keep the motor cool enough?
Mark Henry
I doubt if you can do much to the fan.
Use a cooler for sure.
The single biggest improvments are going to come from getting more cool air into the engine bay.
Use a GT deck lid. If the turbo is going into the bay try to isollate it from the cooling air. If you like to cut and hack maybe some NACA ducts in the rockers (a'la chuckster, I think) and duct them into the engine bay.
Has anyone tried a GT lid with two rain trays? would this help/work?
Maybe I should start a new thread for this question.
cha914
Mueller,
What about water injection? Keep that charge nice and cool...
Also, be sure to block off the ducts that come out of the fan shroud. That will boost the air flow to the heads some, and I am sure you are ceramic coating the header to help with the heat and give a good charge to the turbo.
Good luck,
Tony
fuch toy
Double rain trays? Don't you mean double grills?
I think it was John Rogers that uses a lip spolier on the targa bar....it vents more air from the top of the car, down to the grill(s).....he posts here and should have a pic.
Mark Henry
QUOTE(Zois @ May 14 2003, 07:42 AM)
No, rain trays. I know what a GT lid is.
I want more cooling air, but I want to keep the rain tray function. Has anyone tried it and is it worth it?
I don't know if a scoop like that really works, a lot of air spins around there already. That's why they put those pop-up rear wind screens on Merc's. Ever notice how people's hair blows in a convertable? That's how a 914 can get away with the air intake where it is.
john rogers
Hey Mike, thanks for remembering me. I have a deflector over the rear of the targa top, about 18 inches wide or so and it gets lots of air into the engine grill. It was thought of by Charlie Wallace in san Diego to cool a 914 with an RSR motor that ran a little hot. It sticks up about 1.5 inches which gives plenty of air since it breaks the vacuum behind the rear window. The other alternative would be to take out the rear window so the air coming in the sides goes straight out the back. Most vintage organizations will not allow this as they say rear window required. There are a couple of pictures on the Pelican site in my race car article. Good luck
JmuRiz
Mike Z: Do you have any pics of that dual fan setup, and is it worth it in your oppinion? Because it seems like a cool idea (no pun intended)
fuch toy
http://www.914world.com/bbs2/index.php?act...t=ST&f=2&t=1455
Buried on page 14.....
fuch toy
One
fuch toy
two
Demick
QUOTE(Zois @ May 14 2003, 06:26 AM)
Stock cooling fan is rated at 1680 cfm @ 4600 rpm.
fuch toy
Times 2.....2400 cfm, continuous not contingent on engine speed........
airsix
Mike,
I was talking to an engineer about this just this past weekend. He said that this type of fan and ducting design is about 90% efficient. Other than plugging leaks, there's no practical way to improve on that short of a bigger fan.
Things you can do:
1) get cooler air to the fan
2) fresh-air intake
3) cool the compressed charge (intercooling)
4) increased oil cooling
5) keep turbo heat out of engine bay
I'm taking my fresh-air intake from the right wheel well. I moved my battery to the front trunk to give me room in this area for the plumbing and airbox. I am mounting my turbo next to the bellhousing on the right side, just behind the upright cooling tin to keep it out of the engine bay. I'll post pictures in a week or two.
-Ben M.
Scott S
Mr Z -
do you have to pull the motor for this install? Does that price include the alternator bracketry?
-Scott S
Joe Bob
It's easier to do so....but no. I have mine pulled because I am dong it prior to install because it is an engine swap.
It would be a bitch to pull the front cooling shroud and fan inside a 914....but I guess it could be done.
bernbomb914
I have a extra engine lid that I want to punch louvers in to get more air flow to the engine bay but I dont know anyone that does this work in my area.
It would keep most of the rain from comming in and allow the turbulant air to enter. I dont know which way to face the louvers to get the max flow thru.
seanery
Bernie,
Find a HotRod / StreetRod place.
That is very common for them to do.
jonwatts
Hmm, which way to aim the louvers is a good question.
I would get a pack of 3M post-it notes and stick them to the engine lid. Bend them so they stick straight up. Go for a short drive and use the rearview mirror to see which way they bend. You might even get different results at different locations on the engine lid.
john rogers
We did the same thing when we were trying to figure what to do about cooling my race car off. We used some stips of cloth and tape and found the air flow was very turbulent over the engine lid since the area just behind the windshield is in a vacuum created from the engine sucking in air and the poor aeodynamics of the roof line. That is why we went with the curved air deflector but on a street car it would look really "ricer"! I would face the louver openings to the rear as most hot rods I have seen have theirs that way. Good luck
