Full Version: Intermittent Wipers
steuspeed
Summer is over and the first rain hit today sad.gif I have a 73 and want to add intermittent wipers. What do I need, and where can I get it?
QUOTE(steuspeed @ Oct 12 2012, 12:44 PM) *
- Make sure you have the wiring in the steering column. A early '73 may not have it.
- Get the extension harness. It plugs into your wiper motor connectors and adds a relay socket.
- Get the correct relay
- Brake off the tab on the wiper lever that prevents the lever from going down a notch.
This article mentions the extension harness and relay:
http://www.914world.com/specs/tech_el_washer.php
PS: Do a search here, there are some good threads about the subject already ...
Eric_Shea
I used a 924 switch, a 914-6 pump, a factory intermittent relay and a relay harness from Mr. Bowlsby.
All looks and operates factory... which isn't saying much. If you're electrical savvy, Valy can share his schematic for a better solution. The factory intermittent is really not worth the effort. His will operate at the speed you select with the stalk. Pretty slick.
markb
I have the extension wiring and an NOS relay for sale in the classifieds......
steuspeed
So Mark has the factory 914 harness for intermittent wipers. I believe it was called 'flick wipe'. Does it work just like normal intermittent wipers?
Eric_Shea
Here's how it works, if you have the factory intermittent switch.
Lower the right stalk for intermittent. I don't recall what it is but, it's like a 3-4 second delay. That's it. Better than full on but not amazing by today's standards.
The rest of the stalk works the same; one up for low, two up for not as low as low. biggrin.gif
steuspeed
I saw in the archives that pull give you wash + 4 wipes. I don't know if mine does this now since the washer pump does not work and I never use it. I think my spare needs more tire pressure, or maybe something wrong with the pressure valve.
markb
Sorry, but someone just swooped in & bought my harness.
If you're going to put in the int wipers, you might also go to an electric washer pump. SirAndy has a writeup on how to do that.wipers,
Valy
See this post.
http://www.914world.com/bbs2/index.php?s=&...t&p=1447738
The programmable relay is really nice.
steuspeed
I found that wire diagram on the Samba site I think. That sounds really slick. Now I just need to implement.
steuspeed
Got my #99 programmable wiper relay on the way. Found this hook-up diagram.
http://blue67.co.uk/tech_images/int_wiper_mod.jpg
