QUOTE(timothy_nd28 @ Oct 21 2012, 03:01 PM)
Cool,
Try this, pull the connector off of the cold start valve, then try starting the engine. With this connector off, does it even start? If it starts, does it still run for 20 seconds?
If it runs and nothing is different, reconnect the cold start connector.
Try this next, pull off the connector off of the aux air valve, and try starting the engine, same thing as above.
Remember that white connector that plugs into the dual relay. I know you cleaned it, but pull the connector off and on 33 times. This will help provide a better connection.
Towards the throttle cable, did you find the barrell nut that fell off?
If the above 2 steps fail to show any results, grab a can of starting fluid and spray around the vacuum hoses and different parts of the engine, to look for vacuum leaks. Double check your oil filter cap.
Cold Start pulled, It starts and then stops in about 10 seconds. No big difference
AUX air valve same thing. Starts, runs not quite 20 seconds. The Elbow, Breather Hose/FI Aux Air Valve was cracked bad, so I rigged a hose on the end of the AUX air valve and ended the leak. Still it starts and runs for 20 seconds.
Did the 33x wire jiggle.
Checked all the hoses for leaks. Oil filter tight.
I wonder if the adjustment on the Air Flow Meter is turned too far in one direction?
I don't think it is flooding as it starts quickly. I think either too much air is getting in or something is not closing?
JAA
