Full Version: New fuel level sender
Pat Garvey
Have a new VDO sender & ready to install.....but (pic says it all).
Mikey914
Is there a pin that holds the float? I thinks that's what they are referring to
Spoke
QUOTE(Mikey914 @ Oct 27 2012, 09:26 PM) *
That makes sense. If the float were allowed to move in transit it could easily be damaged.
Pat Garvey
There is no visible pin and the float is movable. It was packed for shipment in a tube with foam rings to hold it safely.
I think the warning sticker is bogus.
timothy_nd28
Your probably right, but did you check behind the sticker? Shipping rods and pins are very common, especially with washing machines.
3d914
QUOTE(timothy_nd28 @ Oct 28 2012, 11:30 AM) *
I agree - look for a pin under the sticker.
bdstone914
Looks like there is a dimple in the center of the sticker.
ConeDodger
Leave it.
Pat Garvey
QUOTE(bdstone914 @ Oct 28 2012, 02:17 PM) *
Nope...nada!
Think VDO is messing with me. There is NO "safety pin" anywhere. Under the warning label is as smooth as the rest. Putting it in as is, with the exception of the warning label.
