...picking up a motor and assorted parts this Saturday in TN:
1- Subaru 2005, 2.5 Liter NA w/o turbo - approx. 100K
2- 5-speed tranny with flywheel and clutch, still attached to engine
3- FI harness and ecu (brain)
4- Complete vehicle harness
5- A/C compressor and dash control pod with dash condenser
6- What's left of gauge pod for speedo, temp, etc
7- Cruise control pod or stalk with associated valving and subassemblies complete out to motor
8- Fuel tank accessory plate with sender, pump, etc (including sub-harness)
9- Complete stub axles and CVs out to wheel
10- Rear differential (not needed - FS later)
Maybe I'll get lucky and score something else I can clean up and sell here to our membership.
I also purchased a Subie motor and tranny mount from Ian over at Coldwater914. Real honest guy I have been corresponding with for a while. Ian's torch skills are outstanding, and I was tempted to leave the steel bare.
What I did was had the cradle lightly sand blasted to eliminate much of the heat discoloration at the joints, although the joints were impeccably finished prior to shipping. After blasting, the steel takes on a nice milky flat tinge that can be left as is, but I wanted to powder coat it to further preserve the work while not blinging it out too much.
I had them apply a clear powder coat with product from nic industries. I think it will stand out on its on against any colors I later apply to the motor or tranny pieces.
Ian is supplying his custom components specific to this conversion, with the coupler, Sway-Away half-shafts, fwd block off plate, and accessories.
More build details will be added as I sort through the project details
Coldwater914 Cradle - 4 or 6 cylinder capable
Click to view attachmentClick to view attachment
