QUOTE(Chris H. @ Nov 29 2012, 06:10 AM)
Mueller commented several times that the engine was VERY tall. Basically designed for a space the opposite of what we have (narrow, taller space instead of wider). You could make it work though. At $300 you just can't lose on that deal! Go for it! I'm sure the rest of the carcass is worth more than the asking price anyway.
There's a 911 VR6 conversion underway. I've been talking with the builder a bit. As you can imagine, the tallness is a bigger problem there. It just barely fits IF you use the Vanagon thermostat housing.
I'd also suggest a different tranny. Either step up to a bigger porsche unit or go for the audi conversion. Bellhousing adapters are available from Kennedy an 034. Once you step into VR6 land and get it sorted, the next thought that eventually goes through your head is "damn, turbos are relatively easy and cheap for these things".
